1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building Static binaries
To: [email protected]
Date: Wed, 5 Oct 2011 11:33:21 -0500
Hi David,
On 2011-10-05 David Dudley wrote:
> I understand that under OSX on the MAC, that you can¹t build static
> binaries.
> Is there a way I can build ³non-static² for the MAC (the HOST machine), and
> static for the target machine?
Any setting you can put into the base/configure/CONFIG_SITE file you can also
add to a base/configure/os/CONFIG_SITE.<xxx>.<yyy> file, so you can set the
STATIC_BUILD=YES and SHARED_LIBRARIES=NO variables in an appropriate
CONFIG_SITE.Common.<arch> file for your target arch (create it if it doesn't
already exist).
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Building Static binaries David Dudley
Prev: Building Static binaries David Dudley
Next: WAGO 750: MBBI and MBBO Record Example? Heiniger Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
