1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Sequence monitor not getting callback
To: "Shankar, Murali" <[email protected]>
Cc: [email protected]
Date: Wed, 5 Oct 2011 07:45:57 -0500
Hi Murali,
On 2011-10-04 Shankar, Murali wrote:
> Separating out the server (process variables) and the client (sequence
> programs) into two separate processes seems to fix this issue. I used the
> same executable for both processes; though for the server I could have
> probably used softIoc.
> So, the issue is perhaps the client part and the server part of
> ca_add_masked_array_event/ca_create_subscription tripping over each other
> if they run within the same process in this context.
<<snip>>
This points to the problem being a bug in the local interface between the CA
client library and the IOC server -- there is a special interface that the
client uses when it's running in the same process as the IOC to access local
channels.  That puts the issue in Jeff Hill's area of responsibility.  He may
not have been following your previous posts, so could you summarize the bug
that you're seeing and explain how to replicate it as simply as possible,
he'll then be able to look further when he has the time to do so.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: Re: Sequence monitor not getting callback Shankar, Murali
Prev: Re: Add new Alarm Status Schoeneburg, Bernd
Next: Building Static binaries David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Re: Sequence monitor not getting callback Shankar, Murali
Next: Re: Sequence monitor not getting callback Benjamin Franksen
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
