1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: building 64-bit base on windows
To: <[email protected]>, <[email protected]>
Date: Thu, 29 Sep 2011 17:35:33 +0000
Thanks. Just tried building 3.14.12.1, with all the same tools and environment, and it works fine.
Cheers,
Matt
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 29 September 2011 16:11
> To: [email protected]
> Cc: Pearson, Matthew (DLSLtd,RAL,DIA)
> Subject: Re: building 64-bit base on windows
> Hi Matt,
> On 2011-09-29 [email protected] wrote:
> > I'm attempting to build a 64-bit version of base 3.14.11 on Windows
> Server
> >  2008. From reading tech-talk, I've not come across this specific
> problem I
> >  have. In the 3.14.12 release notes I saw that windows-x64 support
> was
> >  added for that release, but there are x64 config files in the
> 3.14.11
> >  release. Is it the case that the 3.14.11 support was incomplete and
> that I
> >  need to move to 3.14.12?
> I believe so.  That kind of thing (adding the files to the build system
> but
> not saying anything in the release notes) suggests to me that someone
> might
> have donated them or Janet created them herself but she didn't get them
> to the
> stage where they were fully working.  You would have to look at what
> windows-
> x64 files changed or were added to the configure/os directory in
> 3.14.12 to
> work out what was missing from 3.14.11, but it should be a lot simpler
> to just
> upgrade.
> HTH,
> - Andrew
> Optimization is the process of taking something that works and
> replacing it with something that almost works, but costs less.
> -- Roger Needham
building 64-bit base on windows matthew.pearson
Re: building 64-bit base on windows Andrew Johnson
Prev: Re: Transform Record no_inlink test Tim Mooney
Next: Re: [S7plc EPICS driver] REAL type record jumps to zero Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: building 64-bit base on windows Andrew Johnson
Next: the seq that launched a thousand seqs Laznovsky Michael
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
