Hi- sent as private email, but maybe of interest to the community...
Mike
-----Original Message-----
If you ever need to launch a thousand seqs "for real", you could do what
I'm doing: rather than a humungous startup file, have a separate small
state
set which reads a config file and calls seq() itself for each entry.
The
only fly in the metaphorical ointment appears to be that snl progs seem
to require at least one PV connection to be happy; with no PVs assigned
it complains about "0 out of 0" connections, so you need a dummy PV in
that state program (and Ben just told me that will be fixed in the next
release).
And fwiw, it's better to have the "startup" seq hibernate rather than
die, to ward off resource-destruction demons.
// read -- read one config entry
state read {
when (1) {
%% n = fscanf(fp,"%s %s %s",devName,devType,devCfg);
if (n != 3) {
if (feof(fp)) done = 1;
else { //error
bubu = 1;
} state spawn
// spawn -- spawn one magnet-cycling seq
state spawn {
when (done || bubu) {
if (fp) fclose(fp);
} state done
when (1) { // !done
%% extern struct seqProgram seqMagCycle;
%% char seqParms[99];
%% sprintf(seqParms,"DEV=%s,TYP=%s,CFG=%s",devName,devType,devCfg);
%% seq(&seqMagCycle,seqParms,0);
} state spawn_delay
// spawn_delay -- delay between spawns
state spawn_delay {
#define SPAWN_DELAY 0.333 // adjust to taste
when (SPAWN_DELAY) {
} state read
Re: Transform Record no_inlink test Bruce Hill
RE: building 64-bit base on windows Mark Rivers
<2011>
RE: building 64-bit base on windows matthew.pearson
Regarding Labjack and Xcode Kamleshkumar Suthar (suthar)
<2011>
