I'm attempting to build a 64-bit version of base 3.14.11 on Windows Server 2008. From reading tech-talk, I've not come across this specific problem I have. In the 3.14.12 release notes I saw that windows-x64 support was added for that release, but there are x64 config files in the 3.14.11 release. Is it the case that the 3.14.11 support was incomplete and that I need to move to 3.14.12?
I managed to build the win32-x86 version with no issues, but the windows-x64 version fails the first time the linker is called (error pasted below).
We're using Visual Studio 2010, with GnuWin32 make 3.81 and ActiveState Perl 64-bit 5.12.4. To set up the VS environment I'm calling "vcvarsall.bat" passing "amd64" as an argument.
Here's where the linker fails, after successfully compiling libCom...
link /nologo /subsystem:windows /dll /MANIFEST /LTCG /incremental:no /opt:ref /r
elease /version:3.14 /implib:Com.lib /out:Com.dll
LINK : warning LNK4001: no object files specified; libraries used
LINK : warning LNK4068: /MACHINE not specified; defaulting to X64
LINK : error LNK2001: unresolved external symbol _DllMainCRTStartup
Com.dll : fatal error LNK1120: 1 unresolved externals
make[3]: *** [Com.dll] Error 1120
make[3]: Leaving directory `D:/epics/base/src/libCom/O.windows-x64'
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory `D:/epics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `D:/epics/base/src'
make: *** [src.install] Error 2
There are no object files in the argument list of the linker. There's also an error which seems to indicate it can't find the C runtime libraries.
Any ideas? I've pasted my environment below, in case that's helpful...
Cheers,
Matthew
D:\epics\base>set
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\mp49\AppData\Roaming
APR_ICONV_PATH=C:\Program Files (x86)\Subversion\iconv
CLIENTNAME=pc0034
CommandPromptType=Native
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=DIAMCSTS01
ComSpec=C:\Windows\system32\cmd.exe
EPICS_BASE=D:\epics\\base
EPICS_CA_REPEATER_PORT=6065
EPICS_CA_SERVER_PORT=6064
EPICS_EXTENSIONS=D:\epics\\extensions
EPICS_HOST=WIN32
EPICS_HOST_ARCH=windows-x64
EPICS_MBA_TEMPLATE_TOP=D:\epics\\base\Templates\makeBaseApp\top
EPICS_SUPPORT=W:\epics\\support
FP_NO_HOST_CHECK=NO
Framework35Version=v3.5
FrameworkDir=c:\Windows\Microsoft.NET\Framework64
FrameworkDIR64=c:\Windows\Microsoft.NET\Framework64
FrameworkVersion=v4.0.30319
FrameworkVersion64=v4.0.30319
FSHARPINSTALLDIR=c:\Program Files (x86)\Microsoft F#\v4.0\
HOMEDRIVE=C:
HOMEPATH=\Users\mp49
INCLUDE=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\INCLUDE;c:\Progra
m Files (x86)\Microsoft Visual Studio 10.0\VC\ATLMFC\INCLUDE;C:\Program Files (x
86)\Microsoft SDKs\Windows\v7.0A\include;
LIB=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\LIB\amd64;c:\Program
Files (x86)\Microsoft Visual Studio 10.0\VC\ATLMFC\LIB\amd64;C:\Program Files (x
86)\Microsoft SDKs\Windows\v7.0A\lib\x64;
LIBPATH=c:\Windows\Microsoft.NET\Framework64\v4.0.30319;c:\Windows\Microsoft.NET
\Framework64\v3.5;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\LIB\amd
64;c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\ATLMFC\LIB\amd64;
LOCALAPPDATA=C:\Users\mp49\AppData\Local
LOGONSERVER=\\LOGON05
NUMBER_OF_PROCESSORS=16
OS=Windows_NT
Path=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\BIN\amd64;c:\Windows
\Microsoft.NET\Framework64\v4.0.30319;c:\Windows\Microsoft.NET\Framework64\v3.5;
c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\VCPackages;c:\Program Fil
es (x86)\Microsoft Visual Studio 10.0\Common7\IDE;c:\Program Files (x86)\Microso
ft Visual Studio 10.0\Common7\Tools;C:\Program Files (x86)\HTML Help Workshop;C:
\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\bin\NETFX 4.0 Tools\x64;C:\Pro
gram Files (x86)\Microsoft SDKs\Windows\v7.0A\bin\x64;C:\Program Files (x86)\Mic
rosoft SDKs\Windows\v7.0A\bin;C:\Python26\;C:\Python26\Scripts;C:\Perl64\site\bi
n;C:\Perl64\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windo
ws\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Dell\SysMgt\oma\bin;C
:\Program Files (x86)\Dell\SysMgt\idrac;c:\Program Files (x86)\Microsoft SQL Ser
ver\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Pro
gram Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Subversion\
bin;C:\Windows\System32;C:\Users\mp49\AppData\Roaming\Python\Scripts;C:\Program
Files (x86)\GnuWin32\bin;D:\epics\\base\bin\windows-x64;D:\epics\\extensions\bin
\windows-x64
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.py;.pyw
Platform=X64
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 26 Stepping 5, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=1a05
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
SESSIONNAME=RDP-Tcp#0
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\mp49\AppData\Local\Temp\3
TMP=C:\Users\mp49\AppData\Local\Temp\3
USERDNSDOMAIN=FED.CCLRC.AC.UK
USERDOMAIN=CLRC
USERNAME=mp49
USERPROFILE=C:\Users\mp49
VCINSTALLDIR=c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\
VS100COMNTOOLS=c:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools
VSINSTALLDIR=c:\Program Files (x86)\Microsoft Visual Studio 10.0\
windir=C:\Windows
WindowsSdkDir=C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\
windows_tracing_flags=3
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
Dr Matthew Pearson
Senior Software Systems Engineer
Diamond Light Source
Chilton, Didcot
OX11 0DE
UK
Beamline Controls - I16, I19, B18
- RE: building 64-bit base on windows Mark Rivers
- Re: building 64-bit base on windows Andrew Johnson
Re: Sequence monitor not getting callback Benjamin Franksen
Re: Transform Record no_inlink test Bruce Hill
<2011>
<2011>
