In using the transform record V5.7 from calc 2.8, I found that the record has
a test in transformRecord.c line 398 that disables output calculations for each variable that
has an input link.
If I disable that test for no_inlink, my transform record behaves as I expect.
Does anyone know why that test is there?
It seems to preclude using the transform record input links which select the same PV as the output links.
I can get around it by adding dfanout records to write the values directly to the
transform record input fields, A-P, but it seems like an ugly workaround.
- Bruce
record( ao, "$(CAM):Gain" )
field( DESC, "Set camera gain" )
field( DRVH, "100" )
field( DRVL, "0" )
field( HOPR, "100" )
field( LOPR, "0" )
field( PINI, "YES" )
field( FLNK, "$(CAM):Gain:Calc PP" )
record( ao, "$(CAM):GainA" )
field( DESC, "Gain for side A" )
field( DOL, "0x042" )
field( DRVL, "0x042" )
field( DRVH, "0x1E8" )
record( ao, "$(CAM):GainB" )
field( DESC, "Gain for side B" )
record( ao, "$(CAM):Gain:Offset" )
field( DESC, "Offset between gain halves" )
record( transform, "$(CAM):Gain:Calc" )
field( DESC, "Calc camera gain" )
field( INPA, "$(CAM):GainA" )
field( INPB, "$(CAM):GainB" )
field( INPH, "0x1E8" )
field( INPL, "0x042" )
field( INPO, "$(CAM):Gain:Offset" )
field( INPG, "$(CAM):Gain" )
field( CLCA, "(G/100)*(H-L)+L-(O/2)" )
field( CLCB, "(G/100)*(H-L)+L+(O/2)" )
field( CLCG, "(((A+B)/2)-L)*100/(H-L)" )
field( CLCO, "B-A" )
field( OUTA, "$(CAM):GainA PP" )
field( OUTB, "$(CAM):GainB PP" )
field( OUTG, "$(CAM):Gain PP" )
field( OUTO, "$(CAM):Gain:Offset PP" )
- Re: Transform Record no_inlink test Tim Mooney
Re: [S7plc EPICS driver] REAL type record jumps to zero Steven M. Hartman
<2011>
Xerces Re: problem running Channel Archiver on 64-bit Scientific Linux 6 Kasemir, Kay
<2011>
