1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Asub record problems to update waveforms of string-type
Date: Fri, 23 Sep 2011 14:01:26 +0000
Hello,
I have some problems with the use of the “asub” record. I’m trying to update a waveform record with two strings. So, my EPICS database looks like this:
record(waveform, "$(P):CRExeSeq") {
  field(PINI, "NO")
  field(DTYP, "Soft Channel")
  field(UDF,  "0")
  field(NELM, "2")
  field(FTVL, "STRING")
record(aSub, "$(P):_notifyCRExeSeq") {
  field(SCAN, "Event")
  field(EVNT, "4")
  field(OUTA, "$(P):CRExeSeq")
  field(SNAM, "asub_notify")
  field(PINI, "NO")
  field(FTVA, "STRING")
  field(NOVA, "2")
  field(NEVA, "2")
The “$(P):CRExeSeq” record is updated by the “$(P):_notifyCRExeSeq” record when an observer class executes the “post_event(4)” function.  The problem is that my “asub_notify” function doesn’t really update the string waveform. In this function, I process the update in the following way:
// I get the new informations from an other class
QStringList l_infoAnotifier =
g_drvSequenceurMetier->getCRExecutionSequence();
//Here, I process the update
if(precord->nova <= l_infoAnotifier.size()){
      // I create a char**
      char** l_info =
(char**) malloc(l_infoAnotifier.size()*sizeof(char*));
      for(int i=0;i<l_infoAnotifier.size();i++){
            l_info[i] = (char*) malloc(40*sizeof(char));
            if(l_infoAnotifier.at(i).length()<=40){
      strcpy_s(l_info[i],40,l
   l_infoAnotifier.at(i).toStdString().c_str());
            } else {
                  strcpy_s(l_info[i],40,"Error too much char");
      //Copy
      try {
            char** l_stringout = (char**) precord->vala;
            memcpy_s(l_stringout,(40*precord->nova)*sizeof(char),
                  l_info,(40*l_infoAnotifier.size())*sizeof(char));
      } catch (...) {
            printf("Error in the asub_notify function\n");
      //Delete
      delete[] l_info;
In the same way, I created a process function which seems to work for updating waveform of double-type data. Here, I think the problem comes from the string type and the “memcpy” functions.
Does anyone know how to realize asub functions for string waveforms? Or know why this code doesn’t work?
Cheers,
Pierre PERRIER
Stagiaire - MCO LIL
Sopra group.
Parc Innolin
9 rue du Golf 33700 Merignac
Phone : +33 (0)5 56 12 79 59
[email protected] - www.sopragroup.com
Ce message peut contenir des informations confidentielles dont la divulgation est à ce titre rigoureusement interdite en l'absence d'autorisation explicite de l'émetteur. Dans l'hypothèse où vous auriez reçu par erreur ce message, merci de le renvoyer à l’émetteur et de détruire toute copie.
P Pensez à l’environnement avant d’imprimer.
RE: Asub record problems to update waveforms of string-type Steiner, Mathias
Prev: Re: Combing Two State Sets into One Ned Arnold
Next: RE: Asub record problems to update waveforms of string-type Steiner, Mathias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Combing Two State Sets into One Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
