>4.It would be nice if there was an option to dynamically resize the Data Browser widget at runtime (the Data Browser tab already does this). I thought I could do it with some Javascript but I would need a way to get the current window's width. display.getPropertyValue("width"); will just return the initial width set in the properties at edit time. I would also need some way of triggering the javascript on a display size change. Anyone know if that is possible in BOY?
The Display has a property "Auto Zoom to Fit All" will do what you want. If it is still not what you want, you can call some Java code in script like this:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
importPackage(Packages.org.eclipse.swt.widgets);
importPackage(Packages.org.eclipse.swt);
var shell = Display.getCurrent().getActiveShell();
//Get shell size
var size;
listener = {
handleEvent:function(event){
size=shell.getClientArea();
widget.setPropertyValue("width", size.width);
widget.setPropertyValue("height", size.height);
shell.addListener(SWT.Resize, new Listener(listener));
The script should be triggered only once, so you can set a constant PV is trigger PV, for example "1".
Hope this can help,
Xihui
- Re: BOY Data Browser Issues Craig.Haskins
- BOY Data Browser Issues Craig.Haskins
RE: Time, technology and leaping seconds nick.rees
<2011>
Re: BOY Data Browser Issues Kasemir, Kay
<2011>
