>From time to time it appears as though my sequences don't get their monitor callbacks. Example:
#42 of 196:
Channel name: "KLYS:LI27:51:BVLT"
Unexpanded (assigned) name: ""
Variable name: "BVLT"
address = 203186364 = 0xc1c60bc
type = float
count = 1
Value = 0
Monitor flag = 0
Monitored
Assigned
Connected
Get not completed or no get issued
Put not completed or no put issued
Status = 0
Severity = 0
Message =
Time stamp = 2011/09/15 14:46:40.940
Next? (+/- skip count)
$ caget KLYS:LI27:51:BVLT KLYS:LI27:51:BVLT.MDEL
KLYS:LI27:51:BVLT 349.717
KLYS:LI27:51:BVLT.MDEL 0
The PV is assigned with pvAssign and monitored with pvMonitor.
The PV lives on the same soft ioc as the sequence.
epics> dbpr("KLYS:LI27:51:BVLT",1000)
ACKS: MAJOR ACKT: YES ADEL: 0 ALST: 350.166015625
AOFF: 0 ASG: ASLO: 0 ASP: 0xa7acfe8
BKPT: 00 DESC: Beam Voltage DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DOL:CONSTANT DPVT: (nil)
DRVH: 0 DRVL: 0 DSET: 0x6bf280 DTYP: Soft Channel
EGU: EGUF: 0 EGUL: 0 EOFF: 0
ESLO: 1 EVNT: 0 FLNK:DB_LINK KLYS:LI27:51:BVLTTS
HHSV: NO_ALARM HIGH: 360.000152587891 HIHI: 0
HOPR: 0 HSV: MAJOR HYST: 0 INIT: 0
IVOA: Continue normally IVOV: 0 LALM: 350.166015625
LBRK: 0 LCNT: 0 LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0 LOPR: 0 LOW: 0 LSET: 0xb7b25dc8
LSV: NO_ALARM MDEL: 0
MLIS: 40 0a 70 8a d0 58 5b 0e 03 00 00 00 MLOK: c8 b8 f0 09
MLST: 350.166015625 NAME: KLYS:LI27:51:BVLT NSEV: NO_ALARM
NSTA: NO_ALARM OIF: Full OMOD: 0 OMSL: supervisory
ORAW: 350 ORBV: 0 OROC: 0 OUT:CONSTANT
OVAL: 350.166015625 PACT: 0 PBRK: (nil) PHAS: 0
PINI: YES PPN: (nil) PPNR: (nil) PREC: 6
PRIO: LOW PROC: 0 PUTF: 0 PVAL: 350.166015625
RBV: 0 RDES: 0x81bbc50 ROFF: 0 RPRO: 0
RSET: 0xf66840 RVAL: 350 SCAN: Passive SDIS:CONSTANT
SEVR: NO_ALARM SIML:CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL:CONSTANT SPVT: (nil) STAT: NO_ALARM
TIME: 2011-09-15 14:58:57.976294000 TPRO: 0 TSE: 0
TSEL:CONSTANT UDF: 0 VAL: 350.166015625
More than 99% of the time, the sequence works great, but with 85 klystrons in SLAC's LCLS I see about 1 failure per month. When the sequence starts one of its PVs appears to never get any callbacks. If I restart the sequence, everything is fine.
Using EPICS 3.14.12, sequencer 2.0.11, OS RHEL 4, update 8.
Q: Has anyone else seen this? If so, how did you fix it?
I'm considering upgrading my sequencer to 2.1.2 based on Ben Franksen's notes about fixing bugs in pvAssign and "Safe mode".
Mike
- Re: Sequence monitor not getting callback Benjamin Franksen
RE: aSubRecord VAL field Hu, Yong
<2011>
Re: aSubRecord VAL field Andrew Johnson
<2011>
