I have an application where I'm using aSub to calculate RMS for an array.
It worked fine when I just wanted to generate the RMS value and return it
via VAL. However, when I extended the routine to also calculate MIN
and MAX
and return them via OUT links, I found that if my SNAM routine returns a
non-zero value, it's treated as a status error and aSubRecord.c
suppresses the
updates of the output links.
I'm getting around it by returning zero from my SNAM routine and returning
all my results via OUT link waveforms, but it seems we should either update
the wiki documentation to note this behaviour or modify aSubRecord.c to not
treat the SNAM return value as an error code.
i.e.
--- rec/aSubRecord.c (revision 7338)
+++ rec/aSubRecord.c (working copy)
@@ -269,8 +269,7 @@
if (!status) {
- status = do_sub(prec);
- prec->val = status;
+ prec->val = do_sub(prec);
I'm running base version 3.14.12.
Comments welcome.
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
- RE: aSubRecord VAL field Hu, Yong
Re: Another newbie question - seq record example? Paul Nord
<2011>
RE: ioc linux crash using errlogprintf Davidsaver, Michael
<2011>
