re: zombie - I'm aware of this technique but wanted
to make sure I'm not missing something.
Thanks
-- T.
On 09/13/2011 01:12 PM, Davidsaver, Michael wrote:
-----Original Message-----
[email protected]] On Behalf Of Mark Rivers
Sent: Tuesday, September 13, 2011 1:27 PM
To: Till Straumann; EPICS Techtalk
Subject: RE: asynMotorController exception safety
If your constructor throws an exception, does that automatically
result
in a call to the destructor for the base classes?
Absolutely yes.
If the constructor of an object (or sub-object) completes then its
destructor will be called. Sub-objects may be base classes, or member
objects. This behavior why container classes can effectively manage
resources.
I think the basic problem is that asyn ports can't be unregistered.
When the asynPortDriver instance is destroyed it frees its
asynStandardInterfaces member structure. This leaves asynManager
holding invalid pointers.
@Till, When I face this situation I set a flag if the constructor fails
which prevents the port from ever connecting. Something like:
class myport : asynPortDriver {
bool zombie;
myport::myport()
: zombie(false)
try {
// normal initialization
}catch(...){
zombie=true;
myport::connect(){
if(zombie)
return asynError;
A better solution would be to avoid freeing asynStandardInterfaces.
Michael
I would not have
thought so, but I'm not enough of a C++ expert to know the answer to
that.
Sent: Tuesday, September 13, 2011 11:40 AM
To: EPICS Techtalk; Mark Rivers
Subject: asynMotorController exception safety
I wrote a driver class derived from asynMotorController
(which BTW was easy, thanks for the great package).
I would like the driver to be robust in case e.g., of the
absence of e.g., hardware or a serial communication channel.
Hence, my class does something like:
class MyDrv : public asynMotorController {
public:
MyDrv() : asynMotorController(<parameters go here>)
status = detect_hardware(<parameters>);
if ( status ) {
throw MyException("HW detection failed\n");
In my main application I create a driver object
try {
new MyDrv();
} catch (MyException&e) {
printf("Unable to create driver: %s\n", e.what());
However, if hardware detection fails and the exception
is thrown and subsequently caught then the IOC application
will eventually (later) segfault in asynPortDriver::callbackTask()
(when trying to lock the mutex). It seems that the work
of the superclass constructor(s)
(asynMotorController/asynPortDriver/...) is
not properly undone.
No segfault happens if I comment the entire try block
(including the 'new' statement), i.e., if I create no
driver at all (but still load the .db file etc.).
How am I supposed to handle failure in the constructor?
Thanks
-- Till
- RE: asynMotorController exception safety matthew.pearson
- asynMotorController exception safety Till Straumann
- RE: asynMotorController exception safety Mark Rivers
- RE: asynMotorController exception safety Davidsaver, Michael
Does anyone have VMIC-3123A driver and device support in EPICS 3.14 version? Ma Xiaoyuan
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
