Depending on what your space constraints and travel requirements are you could
try using a LVDT (Linear Variable Differential Transformer)i.e. mainly copper
and Steel. The driver and readout electronics can be many tens of meters away.
Surajit Sarkar
-----Original Message-----
From: [email protected] on behalf of Molina Marinas, Eduardo
Sent: Tue 9/13/2011 3:44 AM
To: [email protected]
Subject: Radhard potentiometers?
Hello,
our group is working on a scraper for the IFMIF-EVEDA project. We are looking
for an adequate position sensor able to withstand high doses of neutrons, in a
linear configuration (no shaft coupled). After searching in the list, it seems
that potentiometers could do the job (accuracy and repeatibility should be in
the 0.01 mm range) Could anyone suggest a particular manufacturer or product?
Thank you,
Eduardo Molina
CIEMAT
Avda.Complutense 40
ES-28040 Madrid
Confidencialidad:
Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario
y puede contener información privilegiada o confidencial. Si no es vd. el
destinatario indicado, queda notificado de que la utilización, divulgación y/o
copia sin autorización está prohibida en virtud de la legislación vigente. Si ha
recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente
respondiendo al mensaje y proceda a su destrucción.
Disclaimer:
This message and its attached files is intended exclusively for its recipients
and may contain confidential information. If you received this e-mail in error
you are hereby notified that any dissemination, copy or disclosure of this
communication is strictly prohibited and may be unlawful. In this case, please
notify us by a reply and delete this email and its contents immediately.
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
The information in this e-mail is intended only for the person to whom it is
addressed. If you believe this e-mail was sent to you in error and the e-mail
contains patient information, please contact the Partners Compliance HelpLine at
http://www.partners.org/complianceline . If the e-mail was sent to you in error
but does not contain patient information, please contact the sender and properly
dispose of the e-mail.
- RE: Radhard potentiometers? Eduardo Molina
- Radhard potentiometers? Molina Marinas, Eduardo
CA Repeater Problem with new installation of EPICS Ziaulhaque Qazi
<2011>
Re: Radhard potentiometers? S. Stein
<2011>
