You need to add the path to the location of caRepeater executable to your PATH environment variable. It is something like epics/base-3.14.12.1/bin/linux-x86.
From: [email protected] on behalf of Ziaulhaque Qazi
Sent: Tue 9/13/2011 8:13 AM
To: [email protected]
Subject: CA Repeater Problem with new installation of EPICS
Hello
I am new to EPICS. I have built the EPICS base R-3.14.12.1 successfully for Scientific Linux 5.
While I created the first application (as advised in Application Developer's Guide) and it looks running without problem.
However when I build the caClient example and tried to run caExample I observe the following messages:
./caExample rootHost:ai3
**** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
rootHost:ai3 3.000000
Also when I start edm for an application here, I notice the same message.
Can anyone help me to find what may be the possible fault in my EPICS installation.
With Regards
Zia-ul-Haque Qazi
Control Engineer
Synchrotron-light for Experimental Sciences and Applications in the Middle East (SESAME)
P. O. Box 7, Allan 19252, Jordan
Phone: +962-5-3511348 Ext: 239
Cell: +962-79-5295527
Fax: +962-5-3511423
- CA Repeater Problem with new installation of EPICS Ziaulhaque Qazi
Re: Radhard potentiometers? S. Stein
<2011>
asynMotorController exception safety Till Straumann
<2011>
