1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: linux-x86_64 and linux-x86 architectures with different include files
To: <[email protected]>, <[email protected]>
Date: Thu, 8 Sep 2011 15:05:20 +0000
Ah, I was using 1-7beta1, I'll have a look at 1-7 now...
Tom Cobb
Tel +44 (0)1235 778582
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 08 September 2011 16:01
> To: Cobb, Tom (DLSLtd,RAL,DIA); [email protected]
> include files
> Hi Tom,
> What version of areaDetector are you using?  This problem is solved for
> you in 1-7.  This is from the hdf5Support/Makefile:
> # OS-specific files in os/ARCH
> # Note, the HFpubconf.h file is OS-specific, generated by configure
> (Linux and Darwin) or supplied by HDF5 Group (Windows)
> INC_Linux    += H5pubconf.h H5pubconf_32.h H5pubconf_64.h
> INC_WIN32    += H5pubconf.h H5pubconf_32.h H5pubconf_64.h
> INC_cygwin32 += H5pubconf.h
> INC_solaris  += H5pubconf.h
> INC_Darwin   += H5pubconf.h
> I edited H5pubconf.h, which contains:
> Colorado:areaDetector/ADApp/hdf5Support>more os/Linux/H5pubconf.h
> #ifdef __LP64__
>   #include "H5pubconf_64.h"
> #else
>   #include "H5pubconf_32.h"
> #endif
> So it uses the appropriate header file.
> Mark
> From: [email protected] [mailto:[email protected]]
> Sent: Thursday, September 08, 2011 9:46 AM
> To: [email protected]
> Cc: Mark Rivers
> Subject: linux-x86_64 and linux-x86 architectures with different
> include
> files
> Hi all,
> I'm looking at building areaDetector under both the linux-x86 and
> linux-x86_64 architectures, unfortunately the HDF5 libraries have
> slightly different headers for each architecture.
> I know that I can do INC_Linux += ... to get different header files for
> each platform under include/os/Linux, but I can't work out if it's
> possible to install and use header files under include/os/linux-x86?
> Does anyone have any ideas? In case it's useful I've attached a diff of
> the offending header file between 32 bit and 64 bit versions.
> Thanks,
> Tom Cobb
> Index: ADApp/hdf5Support/os/Linux/H5pubconf.h
> --- ADApp/hdf5Support/os/Linux/H5pubconf.h	(revision 67256)
> +++ ADApp/hdf5Support/os/Linux/H5pubconf.h	(working copy)
> @@ -511,7 +511,7 @@
>  #define H5_PACKAGE_VERSION "1.8.6"
>  /* Width for printf() for type `long long' or `__int64', use `ll' */
> -#define H5_PRINTF_LL_WIDTH "ll"
> +#define H5_PRINTF_LL_WIDTH "l"
>  /* The size of `char', as computed by sizeof. */
>  #define H5_SIZEOF_CHAR 1
> @@ -538,10 +538,10 @@
>  #define H5_SIZEOF_INT8_T 1
>  /* The size of `int_fast16_t', as computed by sizeof. */
> -#define H5_SIZEOF_INT_FAST16_T 4
> +#define H5_SIZEOF_INT_FAST16_T 8
>  /* The size of `int_fast32_t', as computed by sizeof. */
> -#define H5_SIZEOF_INT_FAST32_T 4
> +#define H5_SIZEOF_INT_FAST32_T 8
>  /* The size of `int_fast64_t', as computed by sizeof. */
>  #define H5_SIZEOF_INT_FAST64_T 8
> @@ -562,10 +562,10 @@
>  #define H5_SIZEOF_INT_LEAST8_T 1
>  /* The size of `long', as computed by sizeof. */
> -#define H5_SIZEOF_LONG 4
> +#define H5_SIZEOF_LONG 8
>  /* The size of `long double', as computed by sizeof. */
> -#define H5_SIZEOF_LONG_DOUBLE 12
> +#define H5_SIZEOF_LONG_DOUBLE 16
>  /* The size of `long long', as computed by sizeof. */
>  #define H5_SIZEOF_LONG_LONG 8
> @@ -577,16 +577,16 @@
>  #define H5_SIZEOF_OFF_T 8
>  /* The size of `ptrdiff_t', as computed by sizeof. */
> -#define H5_SIZEOF_PTRDIFF_T 4
> +#define H5_SIZEOF_PTRDIFF_T 8
>  /* The size of `short', as computed by sizeof. */
>  #define H5_SIZEOF_SHORT 2
>  /* The size of `size_t', as computed by sizeof. */
> -#define H5_SIZEOF_SIZE_T 4
> +#define H5_SIZEOF_SIZE_T 8
>  /* The size of `ssize_t', as computed by sizeof. */
> -#define H5_SIZEOF_SSIZE_T 4
> +#define H5_SIZEOF_SSIZE_T 8
>  /* The size of `uint16_t', as computed by sizeof. */
>  #define H5_SIZEOF_UINT16_T 2
> @@ -601,10 +601,10 @@
>  #define H5_SIZEOF_UINT8_T 1
>  /* The size of `uint_fast16_t', as computed by sizeof. */
> -#define H5_SIZEOF_UINT_FAST16_T 4
> +#define H5_SIZEOF_UINT_FAST16_T 8
>  /* The size of `uint_fast32_t', as computed by sizeof. */
> -#define H5_SIZEOF_UINT_FAST32_T 4
> +#define H5_SIZEOF_UINT_FAST32_T 8
>  /* The size of `uint_fast64_t', as computed by sizeof. */
>  #define H5_SIZEOF_UINT_FAST64_T 8
> @@ -696,7 +696,7 @@
>  #endif
>  /* Number of bits in a file offset, on hosts where this is settable.
> -#define H5__FILE_OFFSET_BITS 64
> +/* #undef H5__FILE_OFFSET_BITS */
>  /* Define for large files, on AIX-style hosts. */
>  /* #undef H5__LARGE_FILES */
> This e-mail and any attachments may contain confidential, copyright and
> or privileged material, and are for the use of the intended addressee
> only. If you are not the intended addressee or an authorised recipient
> of the addressee please notify us of receipt by returning the e-mail
> and
> do not use, copy, retain, distribute or disclose the information in or
> attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual
> and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for
> any
> damage which you may sustain as a result of software viruses which may
> be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in
> England and Wales with its registered office at Diamond House, Harwell
> Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
> Kingdom
linux-x86_64 and linux-x86 architectures with different include files tom.cobb
RE: linux-x86_64 and linux-x86 architectures with different include files Mark Rivers
Prev: Re: windows enable debug build Andrew Johnson
Next: Time-Stamp for Asynchronous records John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: linux-x86_64 and linux-x86 architectures with different include files Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
