Maybe I misunderstand, but can't you simply replace the variable with the same variable ... like this?
file dbAsyn_init.template { pattern {P , R, GROUP, NAME, DLY } {\$(P),\$(R), reg_data, IN0PD , "2" } {\$(P),\$(R), reg_data, IN1PD , "2" } {\$(P),\$(R), reg_data, IN2PD , "2" } {\$(P),\$(R), reg_data, IN3PD , "2" } {\$(P),\$(R), reg_data, IF_SLEEP , "2" } "It works for me" ... as they say. Ned From: "Andrew Johnson" <[email protected]> To: [email protected] Sent: Friday, September 2, 2011 3:01:45 PM Subject: Re: how can I prevent MSI from expanding just some macros? Hi Till, On 2011-09-02 Till Straumann wrote: > I process a bunch of templates with MSI but would like the final > .db file to still contain macros which are to defined when the > .db file is loaded. Of course, this works for macros without > a definition but I'd like to prevent MSI from expanding a macro > that gives a default value: > > $(dont_expand=my_default) > > Is there a way to prevent MSI from expanding this? The obvious way is to use something other than MSI to do this particular expansion, but I expect it's possible to do it using MSI somehow. Maybe instead of spelling them like you do above, you would spell those macros like this: $(dont_expand$(equals)my_default) When you run MSI it will convert that string to this: $(dont_expand$(equals,undefined)my_default,undefined) But that's Ok and still legal. When you're finally ready to expand the dont_expand variable you also set equals='=' and you'll get this as a partial result: $(dont_expand=my_default,undefined) which should then properly expand the dont_expand variable and or set it to my_default if it's not defined. Not tested, and probably rather brittle... - Andrew -- Optimization is the process of taking something that works and replacing it with something that almost works, but costs less. -- Roger Needham
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
