1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Soft IOC question
To: Andrew Cox <[email protected]>, <[email protected]>
Date: Thu, 1 Sep 2011 14:09:29 -0700
Hi Andrew,
One thing that tends to be different for an EPICS software site is that
each IOC typically has it's own release cycle.   Any organization or top
down makefile support for your IOC's is purely for your benefit.
Thus, there are probably nearly as many ways of organizing them as there
are EPICS sites.
The other point to consider is whether or not you intend to make your
own updates or additions to the EPICS base or any of the available
EPICS modules.    To build your IOC, you need have a directory
structure that organizes the various versions of base and modules that
your IOC needs.    If you're also going to make your own versions of
base and/or modules, you'll want those in version control as well.
Here's the way my group organizes them, FWIW.
$(RELEASES)/epics/base/<version>
$(RELEASES)/epics/modules/<module_name>/<version>
$(RELEASES)/epics/ioc/<hutch>/<ioc_name>/<version>
$(RELEASES)/epics/screens/edm/<hutch>/<version>
In svn, it looks like this:
~/svn_wa/epics/base/current
~/svn_wa/epics/modules/<module_name>/current
~/svn_wa/epics/ioc/<hutch>/<ioc_name>/current
~/svn_wa/epics/screens/edm/<hutch>/current
HTH,
- Bruce
On 09/01/2011 08:45 AM, [email protected] wrote:
Try this... and see what comes out!
${EPICS_BASE}/bin/${EPICS_HOST_ARCH}/makeBaseApp.pl -t example base
${EPICS_BASE}/bin/${EPICS_HOST_ARCH}/makeBaseApp.pl -i -t example -a ${TARGET_ARCH} base
I have my own directory structure in my SVN tree.
I built my own makefiles.
No sure you want to do that for only a few IOCs.
The directory structure I have is as follow
.../svn/<synchrotronId>/drivers/<driverName>/{db|doc|medm|qt|msi|iocBoot|dbd|medm|stream|src|...}/
.../svn/<synchrotronId>/iocs/<iocName>/{db|doc|medm|iocBoot|dbd|msi|medm|qt|src|...}/
.../svn/<synchrotronId>/opis/<opiSoftware>/{bin|etc|...}/
The Makefiles build, configure, and install the software based on hostname, arch, etc...
So yes, you can make it as complicated as you want ;-)
Good luck,
E
On 16:02 Wed 31 Aug     , Andrew Cox wrote:
I have downloaded the EPICS IOC core on a redhat machine. I need to run
atleast 3-4 soft IOc on this machine, but i am not able to decide on the
directory structure. i do not want it to be complicated. Can anyone help me
with a directory structure for the database, drivers etc ?
Andrew
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
EPICS Soft IOC question Andrew Cox
Re: EPICS Soft IOC question emmanuel_mayssat
Prev: RE: CA issues on Linux Cid, Florencio A
Next: Re: CA issues on Linux Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Soft IOC question emmanuel_mayssat
Next: CA issues on Linux Cid, Florencio A
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
