1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 'open' epics backup?
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Fri, 26 Aug 2011 10:59:05 -0500
On 08/26/2011 10:54 AM, Tim Mooney wrote:
3/ How do you generate a req file? dbl + manual edit ?
Manual edit.
In the past (more than 6 years ago), I have also generated .req files using a small suite of Tcl scripts. Since then, the backup process was switched to the facility's SDDS-based process that is used at many beam lines.
Pete
Re: 'open' epics backup? Tim Mooney
Prev: Re: 'open' epics backup? Tim Mooney
Next: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: 'open' epics backup? Pelaia II, Tom
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
