1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 'open' epics backup?
To: [email protected]
Date: Thu, 25 Aug 2011 16:20:37 -0500 (CDT)
----- Original Message -----
> I looked at RRDtool.
> Although that is not a backup utility, that's definitly something I
> want to use to move away from
> timeseries using SDDS. (which I also use)
> Just a question: how do you take a time serie of thousands of PV with
> rrdtool at one time T?
> I assume you had to develop a ca plugin/utility, didn't you?
Built support for a specific beam line in Python using PyEpics.
Set CA monitor on each PV.  Python job runs in the background.
Cron job checks periodically to make sure python job restarts
if python job has excepted out.
The supported beam line has ca. 10^2 PVs which is not the same load as your O(10^3) PVs.  Interesting to try.  In my scheme, each PV gets its own RRD database.  Easier to add new PVs without perturbing the existing ones.
Pete
Re: 'open' epics backup? emmanuel_mayssat
Prev: Re: 'open' epics backup? Pelaia II, Tom
Next: RDD of epics pv emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: 'open' epics backup? Chu, Paul
Next: question about best IDEs for Windows/Cygwin-x86, GCC, EPICS in EPICS community Jay Steele
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
