1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Dynamic images in BOY
To: TechTalk <[email protected]>
Date: Thu, 25 Aug 2011 13:31:02 +0200
https://bugs.launchpad.net/epics-base/+bug/701673
~Ralph
On 25.08.2011 12:13, Paweł Prędki wrote:
> Hello,
> I think I found an important clue. Take a look at the table below:
> |     NELM     | Element count returned by cainfo | NELM % 65536 |
> |   40000      | 40000                  | 0         |
> |   65537      | 1                  | 1         |
> |   72900      | 7364                  | 7364     |
> |   90000      | 24464                  | 24464     |
> | 1000000      | 16960                  | 16960     |
> | 2872800      | 54752                  | 54752     |
> It seems like the range limit for the element count is 65536 (2^16)
> and I always get the modulo of the total number of elements in the
> waveform.
> Is there any other CA setting responsible for that?
> Pawel
> W dniu 2011-08-24 12:07, Paweł Prędki pisze:
>> Hello Kay,
>> It's been quite some time since I raised this topic but now I finally
>> managed to try your way for 1-channel images. All in all it works fine.
>> There is one problem, though. The images we're dealing width are of
>> resolution of up to 1710x1680 which is way above the default
>> EPICS_CA_MAX_ARRAY_BYTES value. I changed this environmental variable to
>> 6 000 000 and everything seemed fine again. There were no more errors.
>> However, only 54752 elements are really being sent. I checked it using
>> caget and in BOY.
>> My database entry looks as follows:
>> record(waveform, "CAMERA1:WAVETEST") {
>> field(DTYP, "imgwave")
>> field(NELM, "2872800")
>> field(FTVL, "SHORT")
>> By the way, I tried FTVL, "UCHAR" and I got negative values when the
>> real values exceeded 127 when writing to the waveform in the IOC.
>> I wrote soem very simple device support routines that fill the waveform
>> with counter-like data (0..255) in the read_wf routine. I'm setting the
>> NORD field of the PV to 1710*1680 and it is there afterwards so I know
>> the loop works fine.
>> Do you have any ideas what can be wrong? Is there some other size limit
>> that I am not aware of?
>> Regards,
>> Pawel
>> W dniu 2011-06-06 15:33, Kasemir, Kay pisze:
>>> On 6/6/11 08:59 , "Paweł Prędki"<[email protected]> wrote:
>>>> Is it possible to do such a thing in BOY? There is an Image widget
>>>> but I
>>>> believe it's for static images only.
>>> The "Intensity Graph" widget displays waveforms that are really
>>> grayscale
>>> images.
>>> For example:
>>> waveform with 10000 elements, "width" 100 means:
>>> Elements 0...99 are the first row of the image,
>>> elements 100..199 are the second row of the image and so on.
>>> You need to specify the minimum and maximum element value,
>>> like 0 and 255, which will then be mapped to black...white
>>> or some other color map of your choosing.
>>> -Kay
RE: Dynamic images in BOY Mark Rivers
Re: Dynamic images in BOY Kasemir, Kay
Re: Dynamic images in BOY Paweł Prędki
Prev: Re: Dynamic images in BOY Paweł Prędki
Next: RE: Dynamic images in BOY Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
