1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Dynamic images in BOY
To: "Pawel Predki" <[email protected]>, "Chen, Xihui" <[email protected]>
Cc: TechTalk <[email protected]>
Date: Wed, 24 Aug 2011 21:24:12 -0500
With large arrays and slow networks you might need to increase the timeout on caget from the default of 1 second, using the -w option.
Sent: Wed 8/24/2011 3:25 PM
To: Chen, Xihui
Cc: TechTalk
Subject: Re: Dynamic images in BOY
Hi Xihui,
Yes, I changed that as well. I get the same amount of data as with
caget. That is 54752 for a 1710x1680 'image' and 16960 for 1000x1000.
Could it have anything to do with the fact that it takes some time to
fill the rec->bptr buffer in the read_wf function? I guess not because I
am able to get a nice 40000 element buffer for a 200x200 'image' but I
get LESS than that for 1000x1000.
I don't know if there's another place some kind of limit is set...
Cheers,
Pawel
W dniu 2011-08-24 19:29, Chen, Xihui pisze:
> Hi Pawel,
> Did you set the CSS Prefrences->CSS Core->EPICS->max_array_bytes? CSS doesn't use the environment variable EPICS_CA_MAX_ARRAY_BYTES.
> Thanks,
> Xihui
> -----Original Message-----
> From: Pawel Predki [mailto:[email protected]]
> Sent: Wednesday, August 24, 2011 6:07 AM
> To: Kasemir, Kay
> Cc: TechTalk
> Hello Kay,
> It's been quite some time since I raised this topic but now I finally
> managed to try your way for 1-channel images. All in all it works fine.
> There is one problem, though. The images we're dealing width are of
> resolution of up to 1710x1680 which is way above the default
> EPICS_CA_MAX_ARRAY_BYTES value. I changed this environmental variable to
> 6 000 000 and everything seemed fine again. There were no more errors.
> However, only 54752 elements are really being sent. I checked it using
> caget and in BOY.
> My database entry looks as follows:
> record(waveform, "CAMERA1:WAVETEST") {
>       field(DTYP, "imgwave")
>       field(NELM, "2872800")
>       field(FTVL, "SHORT")
> By the way, I tried FTVL, "UCHAR" and I got negative values when the
> real values exceeded 127 when writing to the waveform in the IOC.
> I wrote soem very simple device support routines that fill the waveform
> with counter-like data (0..255) in the read_wf routine. I'm setting the
> NORD field of the PV to 1710*1680 and it is there afterwards so I know
> the loop works fine.
> Do you have any ideas what can be wrong? Is there some other size limit
> that I am not aware of?
> Regards,
> Pawel
> W dniu 2011-06-06 15:33, Kasemir, Kay pisze:
>> On 6/6/11 08:59 , "Pawel Predki"<[email protected]>   wrote:
>>> Is it possible to do such a thing in BOY? There is an Image widget but I
>>> believe it's for static images only.
>> The "Intensity Graph" widget displays waveforms that are really grayscale
>> images.
>> For example:
>> waveform with 10000 elements, "width" 100 means:
>> Elements 0...99 are the first row of the image,
>> elements 100..199 are the second row of the image and so on.
>> You need to specify the minimum and maximum element value,
>> like 0 and 255, which will then be mapped to black...white
>> or some other color map of your choosing.
>> -Kay
Pawel Predki
Technical University of Lodz
Department of Microelectronics and Computer Science
ul. Wolczanska 221/223, 90-924 Lodz, Poland
tel. +4842 6312720
Re: Dynamic images in BOY Kasemir, Kay
Re: Dynamic images in BOY Paweł Prędki
RE: Dynamic images in BOY Chen, Xihui
Prev: RE: Dynamic images in BOY Mark Rivers
Next: Re: ether_ip driver for ControlLogix PLCs and 'BOOL' tags John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Dynamic images in BOY Paweł Prędki
Next: Re: Dynamic images in BOY Paweł Prędki
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
