Hi Paul,
It is helpful to know the OS and version of EPICS base that you are using. Also provide the output from the full dbpr results from the IOC:
dbpr("GROUP_0", 5)
Thank you,
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Paul Nord
> Sent: Wednesday, August 24, 2011 2:10 PM
> To: [email protected]
> Subject: Newbe question - PV limits
> I've got a GUI setup with MEDM to control some values. I'd like to PV to accept values
> only in a valid range: 4 or 5.
> Here's the record:
> record(longout, "GROUP_0")
> field(DESC, "SNMP channel BBM-")
> field(DTYP, "Snmp")
> field(SCAN, "Passive")
> field(EGU, "")
> field(PINI, "YES")
> field(OUT, "@$(HOST) guru WIENER-CRATE-MIB::groupsSwitch.0 INTEGER: 100
> i")
> field(ADEL, "1")
> field(VAL, "5")
> field(LOPR, "5")
> field(HOPR, "4")
> field(DRVH, "5")
> field(DRVL, "4")
> I've tried setting LOPR, HOPR, and DRV*. But I can still sent "1" from MEDM and it
> will set the hardware into an undesired mode.
> I must be missing something simple here.
> Paul
- Newbe question - PV limits Paul Nord
ether_ip driver for ControlLogix PLCs and 'BOOL' tags Kasemir, Kay
Re: Newbe question - PV limits Ron Sluiter
<2011>
<2011>
