I added EPICSlinux to the hosts file as just a local host. I am still getting the same issue. In the address list all I have in there right now is 127.0.0.1. Thanks for the help. Cheers, Adam Gluck | Applications Engineer | National Instruments From: "Kasemir, Kay" <[email protected]> To: Adam Gluck <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]> Date: 08/19/2011 10:51 AM Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Hi: You have an <west coast>interesting</west coast> computer network setup ;-) The root of your problem seems to be this: com.cosylab.epics.caj.impl.ConnectionException: Failed to connect to '/127.0.0.1:5064'. at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:138) ... Caused by: java.net.UnknownHostException: EPICSlinux: EPICSlinux at java.net.InetAddress.getLocalHost(InetAddress.java:1354) I don't know exactly why the CAJ library wants to resolve a host name in that context. Do you explicitly use "EPICSlinux" in your address list? In the past, there have been similar issues because just so that it would later be able to present you with nice looking error messages, the CA client library tried to resolve host names. Maybe that's related? In any case, it might help to define EPICSlinux as a host in /etc/hosts so that the name resolution 'works'. -Kay
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
