On 8/19/11 10:18 AM, Andrew Johnson wrote:
> If you want to know when the VAL field has been set you should be able to use
> ca_create_subscription() to monitor that or some other related record field.
> One problem with using the motor.VAL field though is that it's used as both an
> input (the user's demand position) and an output field (the current position),
> so you'd get monitor events while the motor is moving. That might not be what
> actually want, so you should look at the other fields available and see if
> monitoring one of them might be more appropriate for your purposes.
Hi, Andrew.
Are you talking about the EPICS motor record? The VAL field is
only updated after the move completes if certain logic makes it
get synced with the RBV field. The VAL field does not update as
the motor moves. The RBV field does.
Lewis
- Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Andrew Johnson
- question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
- RE: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
