Hi:
On 8/19/11 10:49 , "Mark Rivers" <[email protected]> wrote:
> Is there a firewall running on that machine?
I think he said a command-line caget on the same machine worked OK,
but still worth trying.
Does your computer have more than one network card?
> Is there a jcaLibrary.properties file that could be settings things for Java
> differently than the environment variables for the C utilities?
Neither a jcaLibrary.properties file nor environment variables should
matter. CSS is setting the JCA/CAJ libraries from Eclipse preferences
( http://sourceforge.net/apps/trac/cs-studio/wiki/HierarchicalPreferences ),
i.e. basically what you see under CSS/Preferences/.../EPICS.
> Thanks for the advice but setting the IP address did not help, I am just
> trying to access the variables on my own machine and have tried localhost
> and 127.0.0.1.
When using CAJ, make sure you try both with and without the "auto" address
list in combination with "127.0.0.1".
> I did try the logging method and saw at first I was not
> linking correctly to a shared library,
> but was able to fix the and no
> longer have the error.
What was that error?
Did that only happen when you selected the JNI version of JCA,
i.e. not the 'pure java' version under CSS/Preferences/.../EPICS
-> That's expected unless you're running on the few architectures
where we have the JNI binaries included.
> I don't see any error message about the PV other
> then it saying it is disconnected. I am attaching my log file to see if
> that might help. Thanks once again for the help.
The log file shows that you're using the "pure Java" JCA.
Also: What's your CA server?
Is it an ordinary IOC, or some other type of CA server?
If you increase the log level (CSS/Preferences/...) to 'FINE' or higher,
you should see more detail:
PV channel created, connected, received meta data, ....
Maybe that'll help.
Kay
- Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
- RE: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Mark Rivers
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Ralph Lange
Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Andrew Johnson
<2011>
<2011>
