On 8/18/11 3:26 PM, Tim Mooney wrote:
> Awesome! I haven't reproduced the symptom on my x86_64 system, but
> anyway it's clear that the code needs this fix. I'll look for other
> similar problems.
> Thanks to you both.
> Tim
Hi, Tim.
I think I've found another problem: using SSCANF to parse '-1'
with a '%d' format does not result in a value of -1. Attached
is scalcout-corrupt2.db which demonstrates this. After loading
it into an IOC, I did the following from a Bash shell:
$ caget ioc23:Temperature.{VAL,SVAL}
ioc23:Temperature.VAL 4.29497e+09
ioc23:Temperature.SVAL 4294967295.000
The value should be -1.
Like the previous problem, it works fine with the i386
architecture class.
And if I change the '%d' to '%ld', it works fine for the x86_64
architecture class.
Lewis
# Demonstrates scalcout data corruption on 64-bit IOC (darwin-x86 with x86_64
# architecture class; EPICS Base 3.14.12.1 + Known Problems patches). Works
# OK with i386 architecture class IOC. Works OK with x86_64 architecture
# class if use '%ld' instead of '%d'.
# Parameters:
# P PV prefix (e.g. ioc23:)
record(stringin, "$(P)ReadTemperature") {
field(VAL, "!DT -1")
field(FLNK, "$(P)Temperature")
field(PINI, "YES")
record(scalcout, "$(P)Temperature") {
field(INAA, "$(P)ReadTemperature.VAL NPP MS")
field(CALC, "SSCANF(AA,'!DT %d')")
field(EGU, "C")
- Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Bruce Hill
- Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Tim Mooney
RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
<2011>
<2011>
