1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class
Cc: [email protected]
Date: Thu, 18 Aug 2011 14:43:54 -0500
On 8/18/11 2:13 PM, Andrew Johnson wrote:
> I'm guessing the scalcout record type (which is from synApps, not part of
> Base) is probably using long for integer value storage in some places without
> properly initializing the memory.  An LP64 architecture is liable to this kind
> of problem (which is why Base maps DBF_LONG to epicsInt32), so I'd expect
> linux-x86_64 to exhibit it as well although I haven't tried as I don't have
> synApps installed.
Hi, Andrew.
Bingo!  I think you're absolutely right.  After applying the
attached patch to [calc 2-8]/calcApp/src/sCalcPerform.c, it now
works.  Thanks for the hint!
Tim: Maybe other local variables in the sCalcPerform function
should be initialized too?  I don't know.
Lewis
--- sCalcPerform.c.orig	2010-03-24 10:35:17.000000000 -0500
+++ sCalcPerform.c	2011-08-18 14:31:43.000000000 -0500
@@ -357,9 +357,9 @@
 	char				*s2, tmpstr[TMPSTR_SIZE], currSymbol;
 	char				*s, *s1, c;
 	int					i, j, k;
-	long				l;
+	long				l = 0L;
 	unsigned short		ui;
-	unsigned long		ul;
+	unsigned long		ul = 0UL;
 	float				f;
 	double				d;
 	double				*topd, *pd;
Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Tim Mooney
Scalcout data corruption on darwin-x86 with x86_64 arch class J. Lewis Muir
Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Andrew Johnson
Prev: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Andrew Johnson
Next: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
