1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Building EPICS (3-14-12-1) on Windows 7
From: "Williams Jr., Ernest L." <[email protected]>
To: Jüri Tagger <[email protected]>
Date: Thu, 18 Aug 2011 07:35:07 -0700
Hi Juri,
When I try with the unpatched version of EPICS BASE base-3-14-12-1  I get:
rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../
src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/li
bCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../sr
c/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I
../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error
 -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCo
m/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../
src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../.
./src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I.
./../../include/os/WIN32 -I../../../include        -fo Com.res ../Com.rc
Microsoft (R) Windows (R) Resource Compiler Version 6.1.7600.16385
Copyright (C) Microsoft Corporation.  All rights reserved.
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPR
ECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MD  /TP   -I. -
I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\l
ibCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\
src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvt
Fast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -
I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\s
rc\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmg
r -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..
\\..\\src\\libCom\\iocsh<file://..//src//libCom//iocsh> -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\
\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -
I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\
src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
  ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
bucketLib.c
..\..\..\src\libCom\bucketLib\bucketLib.c(125) : error C2440: 'initializing' : c
annot convert from 'const void *' to 'const char *'
        Conversion from 'void*' to pointer to non-'void' requires an explicit ca
st
..\..\..\src\libCom\bucketLib\bucketLib.c(147) : error C2440: 'initializing' : c
annot convert from 'const void *' to 'const unsigned int *'
st
..\..\..\src\libCom\bucketLib\bucketLib.c(197) : error C2440: 'initializing' : c
st
make[3]: *** [bucketLib.obj] Error 2
make[3]: Leaving directory `C:/epics/base/base-R3-14-12-1/src/libCom/O.win32-x86
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory `C:/epics/base/base-R3-14-12-1/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `C:/epics/base/base-R3-14-12-1/src'
make: *** [src.install] Error 2
C:\epics\base\base-R3-14-12-1>
Ernest
Sent: Thursday, August 18, 2011 12:41 AM
To: Williams Jr., Ernest L.
Good morning,
I built 3.14.12.1 on Windows 7 with Visual Studio 2010 straightforward. Patch,  http://www.aps.anl.gov/epics/tech-talk/2010/msg00595.php , is not necessary. I did it with make-3.82-3-mingw32 and ActivePerl-5.12.2.1203-MSWin32-x86
It should work! (Provided paths and environment variables are right.) The only thing I had to do was to run the bat file:
"C:\Program Files\Microsoft Visual Studio 10.0\Common7\Tools\vsvars32.bat"
(use quotation marks for entering this command line) On success it prints out:
Setting environment for using Microsoft Visual Studio 2010 x86 tools.
set  EPICS_HOST_ARCH=win32-x86
C:\MinGW\bin\mingw32-make (while standing in the EPICS base directory).
Cheers,
J. Tagger
MAX - lab
RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
Building EPICS (3-14-12-1) on Windows 7 Williams Jr., Ernest L.
Prev: RE: Building EPICS (3-14-12-1) on Windows 7 Williams Jr., Ernest L.
Next: RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
