On 8/11/2011 12:17 AM, Kathryn Spiers wrote:
Hello,
Further to the discussion in http://www.aps.anl.gov/epics/tech-talk/2011/msg00585.php, I have been trying to open edm windows at specified locations from the command line. I can't get that to work, but before that, can't seem to get the edm display file server and related operations to work.
Firstly,
edm -server
or
edm -server -display $DISPLAY
both open an instance of edm.
Subsequently:
edm -x -open file.edl
returns the error "No server found for display - abort"
This error is returned even if the -display option is included before -open
This works for me, provided that I started the server with the -display
option. If I connect in with ssh, "echo $DISPLAY" displays
"localhost:19.0" Is it possible that the DISPLAY variable is set
incorrectly? (If $DISPLAY is an empty string, then 2 copies of the edm
server would have to be loaded for -open to work).
I've tried edm versions 1.10.1w, 1.12.39 and 1.12.56.
(I'm using edm 1.12.40, but I don't think 1.12.39 is much different, it
looks as though 1.12.58 might have some relevant changes)
However, if I don't use the -display option when starting edm -server,
then I get the same error message, unless 2 copies of the edm server are
running. I suspect this is a bug in locating the edm server, as edm
-one -server will allow me to load exactly 2 copies of edm. On the
production systems, we typically run multiple servers, and use the -port
option to select the correct one when giving the -open command (rather
than -display). In either case the -display is necessary for the -server
command, but not with the -open command.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
- EDM start window position, from command line Kathryn Spiers
devIocStats 3.1.6 released Allison, Stephanie
RE: question about state notation language logic for when() with delay Jay Steele
<2011>
<2011>
