1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: question about state notation language logic for when() with delay
To: <[email protected]>
Date: Wed, 10 Aug 2011 20:06:38 +0200
Hi Jay
Ron answered your question correctly, so let me just add that this is
documented in the (new) manual; quoting from http://www-
csr.bessy.de/control/SoftDist/sequencer/Reference.html#delay:
 boolean delay(double delay_in_seconds)
 Returns whether the specified time has elapsed since entering the state. It
 should be used only within a when expression.
Am Mittwoch, 10. August 2011, um 19:00:51 schrieb Chestnut, Ronald P.:
> The timer starts when the state containing the when clause is entered.
> There are some flags which determine if it restarts when the state loops
> back to itself or not.
> So the order of elements in the when expression is irrelevant.
With respect to the position of  delay()  calls this is true, but in general
the order may of course be relevant, for instance in
  when(a > 0 && 1/a > b)
Evaluation of expressions proceeds exactly as in C, including the order of
side-effects. (It is, however, recommended to use only effect-free expressions
in  when()  clauses.)
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: question about state notation language logic for when() with delay Jay Steele
Re: question about state notation language logic for when() with delay Chestnut, Ronald P.
Prev: Re: question about state notation language logic for when() with delay Chestnut, Ronald P.
Next: EDM start window position, from command line Kathryn Spiers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: question about state notation language logic for when() with delay Jay Steele
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
