1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Erros running st.cmd
To: "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 Aug 2011 12:49:19 -0700
Andrew, attached is the makefile you requested.  Any help/assistance will be greatly appreciated.
Thanks in advance
Flo
-----Original Message-----
Sent: Friday, August 05, 2011 1:37 PM
To: [email protected]; Cid, Florencio A
Cc: [email protected]
Subject: Re: Erros running st.cmd
On 2011-08-05 Shen, Guobao wrote:
> Looks like you do not have envPaths file generated under your
> iocBoot/firstioc.
> Check your Makefile to make sure your ARCH is set correctly, and run make
> under iocBoot/firstioc again.
I disagree, you can see the contents of his envPaths file being output
immediately following the redirect (the lines containing "epicsEnvSet"), so
that file must be present.  This looks like a stranger kind of error, as his
shell doesn't understand any of the commands in the startup script — almost
all of the error messages were "Command x not found."
Florencio,
Please send us the contents of the Makefile that created your FirstIOC
executable, in your c:/firstIOCtop/firstApp/src or similarly named directory.
There's something wrong there, but I can't guess what it is from what you've
posted so far.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Attachment: Makefile
Description: Makefile
Re: Erros running st.cmd Andrew Johnson
Erros running st.cmd Cid, Florencio A
Re: Erros running st.cmd Shen, Guobao
Prev: Re: Erros running st.cmd Andrew Johnson
Next: Re: Erros running st.cmd Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
