On 2011-08-05 Shen, Guobao wrote:
> Looks like you do not have envPaths file generated under your
> iocBoot/firstioc.
> Check your Makefile to make sure your ARCH is set correctly, and run make
> under iocBoot/firstioc again.
I disagree, you can see the contents of his envPaths file being output
immediately following the redirect (the lines containing "epicsEnvSet"), so
that file must be present. This looks like a stranger kind of error, as his
shell doesn't understand any of the commands in the startup script — almost
all of the error messages were "Command x not found."
Florencio,
Please send us the contents of the Makefile that created your FirstIOC
executable, in your c:/firstIOCtop/firstApp/src or similarly named directory.
There's something wrong there, but I can't guess what it is from what you've
posted so far.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- RE: Erros running st.cmd Cid, Florencio A
- Erros running st.cmd Cid, Florencio A
- Re: Erros running st.cmd Shen, Guobao
<2011>
<2011>
