1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Waveform Digitizers (Generic Transient Recorders)
From: "Williams Jr., Ernest L." <[email protected]>
To: "Lawrence T. Hoff" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Fri, 22 Jul 2011 12:58:16 -0700
Hi Larry,
Are you happy with performance and noise specs?
Cheers
Ernest
Sent from my iPhone
On Jul 22, 2011, at 10:13, "Lawrence T. Hoff" <[email protected]> wrote:
> Ernest L. Williams Jr. wrote:
>> Hi,
>> Has anyone used the following waveform digitizer or an
>> equivalent/similar digitizer?
> I have used the CAEN V1729, 14-bit, 2GS/s, 300MHz, shallow
> memory (2500 samples), 4-channel digitizer. Does that help?
> If so, I have both LINUX and VxWorks S/W I can share - but
> not EPICS...
> http://www.caen.it/csite/CaenProd.jsp?parent=11&idmod=593
>> SIS3350 VME FlashADC, 500MHz
>> 4 channels, 500 MHz sampling frequency, 12-bit
>> resolution, 128 MSample/channel memory, multi event
>> mode, 50 Ohm Impedance, Offset DACs, variable gain
>> amplifiers
>> If so, has what is the state of EPICS support?
>> At SLAC we are very interested in the Struct Sis3302 as well.
>> I am aware of a vxWorks driver for SIS3302; should that be integrated
>> into the GTR package?
>> Thanks in advance for any feedback or comments.
>> Cheers,
>> Ernest
Waveform Digitizers (Generic Transient Recorders) Ernest L. Williams Jr.
Re: Waveform Digitizers (Generic Transient Recorders) Lawrence T. Hoff
Prev: asyn support for local serial ports on win32-x86 Mark Rivers
Next: Re: USB/ASYN/EPICS example (usbMouse support) Circuit6 Engineering
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Waveform Digitizers (Generic Transient Recorders) Lawrence T. Hoff
Next: USB/ASYN/EPICS example (usbMouse support) Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
