Hi Charles,
>I've tested the version 3.0.0 of CSS/BOY and I guess the bug wasn't fixed because the menu always appears when I restart CSS in "OPI runtime". Or may be my process to do this isn't good.
Sorry, it was my misleading. The compact mode cannot be restored after CSS restarted. To achieve this function, I plan to add two static methods to ScriptUtil: ScriptUtil.compactMode() and ScriptUtil.fullScreen(). You can attach a script to your OPI to force it to compact mode whenever the OPI is started. Again, these methods are available in next release.
>Secondly, I tried, to launch an opi file in other window CSS/BOY (not in a new tab) by a click on Action Button. The only solution I've found is to attach a "Execute _javascript_" in property Actions.
You can right click the action button and select “Open in new window” or Press “Shift” while clicking to launch an opi in new window.
Xihui
