1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Where is histogram?
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Thu, 21 Jul 2011 12:51:05 -0400
Title: Re: Where is histogram?
The histogram record is a good diagnostic if you are looking for a noisy signal. Please keep it available.
Bob
From: [email protected] on behalf of Andrew Johnson
Sent: Thu 7/21/2011 12:01 PM
To: [email protected]
Subject: Re: Where is histogram?
Hi Mark,
On 2011-07-21 Vigder, Mark wrote:
> I started building an IOC using the histogram record and it gave me an
>  "unknown type" error. I checked the source (I'm using EPICS 3.14.12) and
>  even though the record is defined in <EPICSBASE>/src/rec it's not included
>  in <EPICSBASE>/src/misc/base.dbd. In fact it's the only record defined in
>  /src/rec that is not there.
> This leads me to a number of questions:
> -Is this just a bug? Or is histogram an obsolete record?
Interesting; I'm going to guess that you're not necessarily the first person
to *notice* this, but I think you're the first to point it out on tech-talk.
I don't believe the omission is deliberate, it's just that the histogram
record type is fairly specialized and is not used much any more.  It it looks
like the last time anyone made any significant changes to the code (other than
just updating it to match API and coding style changes elsewhere in Base) was
in October 1998.
> -Does this mean nobody is actually using the histogram record?
I can answer that for the APS: we have a total of 4 (four) histogram records
across the whole of our 320-odd IOCs and well over half a million records in
our accelerator control system.  Any other histogram users out there want to
speak up?
> -If nobody uses histogram, what do they use? Waveform?
I would guess other people are using subroutine or array subroutine records,
and for some uses just a calc or calcout record might suffice.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Where is histogram? Andrew Johnson
Where is histogram? Vigder, Mark
Prev: Re: Where is histogram? Andrew Johnson
Next: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Where is histogram? Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
