Hi:
>> It looks like your Java version is 1.4.2, but CSS needs Java 1.6.0 and up to run
>> it. Please install the latest Java version and try again.
> I download the CSS_EPICS_2.2.0 version. When I excute "./css" , errors came as follows:
> at gnu . gcj . runtime . FirstThread . run() (/usr/lib/libgcj.so.5.0.0)
You're using the gnu GCJ almost-like-java java compiler.
You need to install the real sun/oracle java.
At the same place where you downloaded CSS_EPICS, see "Known Issues":
" CSS Won't run
If it doesn't run at all, see Java Versions.
Linux
In a terminal, run "java -version". RedHat Linux by default includes the GNU version of Java. This will not work, you have to get the Sun Java 1.6.
-Kay
- CSS errors: cannot excute Ma Xiaoyuan
- RE: CSS errors: cannot excute Chen, Xihui
RE: streamdevice + asyn stuck Zhang, Dehong
<2011>
Re: RE: CSS errors: cannot excute Ma Xiaoyuan
<2011>
