1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Errors building EPICS with MinGW
To: "'Morgan Bradford'" <[email protected]>, <[email protected]>
Date: Thu, 7 Jul 2011 15:12:57 -0600
Hi Morgan,
I don’t appear to have any issues building the latest off of the R3.14 branch with mingw. I notice that you have the pedantic command line option turned on, and many other compiler configurations are different.
I am guessing that you don’t have “EPICS_HOST_ARCH=win32-x86-mingw” in your environment, or alternatively your environment has a compile rule that is overriding the rules in the EPICS makefiles.
This builds here:
gcc  -c             -D_MINGW     -g   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I./../../../src/libCom/osi/os/WIN32 -I./../../../src/libCom/osi/os/posix -I./../../../src/libCom/osi/os/default -I.. -I./../../../src/libC
om/bucketLib -I./../../../src/libCom/ring -I./../../../src/libCom/calc -I./../../../src/libCom/cvtFast -I./../../../src/libCom/cppStd -I./../../../src/libCom/cxxTemplates -I./../../../src/libCom/dbmf -I./../../../src/libCom/ellLib -
I./../../../src/libCom/env -I./../../../src/libCom/error -I./../../../src/libCom/fdmgr -I./../../../src/libCom/freeList -I./../../../src/libCom/gpHash -I./../../../src/libCom/iocsh -I./../../../src/libCom/logClient -I./../../../src/
libCom/macLib -I./../../../src/libCom/misc -I./../../../src/libCom/osi -I./../../../src/libCom/taskwd -I./../../../src/libCom/timer -I./../../../src/libCom/yajl -I./../../../src/libCom/BaseString -I./../../../include/os/WIN32 -I./..
/../../include        ./../../../src/libCom/bucketLib/bucketLib.c
This compiler builds here:
$ gcc -v
Using built-in specs.
COLLECT_GCC=C:\MinGW\bin\gcc.exe
COLLECT_LTO_WRAPPER=c:/mingw/bin/../libexec/gcc/mingw32/4.5.2/lto-wrapper.exe
Target: mingw32
Configured with: ../gcc-4.5.2/configure --enable-languages=c,c++,ada,fortran,obj
c,obj-c++ --disable-sjlj-exceptions --with-dwarf2 --enable-shared --enable-libgo
mp --disable-win32-registry --enable-libstdcxx-debug --enable-version-specific-r
untime-libs --disable-werror --build=mingw32 --prefix=/mingw
Thread model: win32
gcc version 4.5.2 (GCC)
This is what failed to build at your site:
g++ -c              -pedantic  -O3  -Wall          -D__cplusplus  -I. -I.. -I../
../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCo
m/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../.
./src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../..
/../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logCl
ient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libC
om/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/l
ibCom/tsDefs -I../../../include/os/WIN32 -I../../../include         ../../../src
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
From: [email protected] [mailto:[email protected]] On Behalf Of Morgan Bradford
Sent: Thursday, July 07, 2011 1:14 PM
To: [email protected]
Subject: Errors building EPICS with MinGW
I am trying to install EPICS Base on a Windows 7 computer, but keep getting the following error. I’ve tried two different builds, 3.14.9 and 3.14.12.1, and have the same problem with both. Any ideas?
Thanks in advance for your help!
Cmd Output:
C:\Users\bradfom>cd c:\epics\base-3.14.9
c:\epics\base-3.14.9>set EPICS_HOST_ARCH=win32-x86-mingw
c:\epics\base-3.14.9>mingw32-make
mingw32-make -C configure install
mingw32-make[1]: Entering directory `c:/epics/base-3.14.9/configure'
c:/Perl/bin/perl.exe ../configure/tools/makeMakefile.pl O.win32-x86-mingw ../..
c:/Perl/bin/perl.exe ../configure/tools/mkdir.pl O.Common
mingw32-make -C O.win32-x86-mingw -f ../Makefile TOP=../.. T_A=win32-x86-mingw i
nstall
mingw32-make[2]: Entering directory `c:/epics/base-3.14.9/configure/O.win32-x86-
mingw'
c:/Perl/bin/perl.exe ../../configure/tools/convertRelease.pl -h win32-x86-mingw
CONFIG_APP_INCLUDE
mingw32-make[2]: Leaving directory `c:/epics/base-3.14.9/configure/O.win32-x86-m
ingw'
mingw32-make[1]: Leaving directory `c:/epics/base-3.14.9/configure'
mingw32-make -C src install
mingw32-make[1]: Entering directory `c:/epics/base-3.14.9/src'
mingw32-make -C libCom install
mingw32-make[2]: Entering directory `c:/epics/base-3.14.9/src/libCom'
c:/Perl/bin/perl.exe ../../configure/tools/makeMakefile.pl O.win32-x86-mingw ../
c:/Perl/bin/perl.exe ../../configure/tools/mkdir.pl O.Common
mingw32-make -C O.win32-x86-mingw -f ../Makefile TOP=../../.. T_A=win32-x86-ming
w install
mingw32-make[3]: Entering directory `c:/epics/base-3.14.9/src/libCom/O.win32-x86
-mingw'
mingw32-make[3]: Leaving directory `c:/epics/base-3.14.9/src/libCom/O.win32-x86-
mingw'
-mingw'
c:/Perl/bin/perl.exe ../../../src/libCom/misc/makeEpicsVersion.pl ../../../confi
gure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.14.9
Installing generated generic include file ../../../include/epicsVersion.h
mkdir ../../../include
Installing generic include file ../../../include/bucketLib.h
Installing generic include file ../../../include/epicsRingPointer.h
Installing generic include file ../../../include/epicsRingBytes.h
Installing generic include file ../../../include/postfix.h
Installing generic include file ../../../include/cvtFast.h
Installing generic include file ../../../include/epicsAlgorithm.h
Installing generic include file ../../../include/epicsExcept.h
Installing generic include file ../../../include/epicsMemory.h
Installing generic include file ../../../include/resourceLib.h
Installing generic include file ../../../include/tsDLList.h
Installing generic include file ../../../include/tsSLList.h
Installing generic include file ../../../include/tsMinMax.h
Installing generic include file ../../../include/tsBTree.h
Installing generic include file ../../../include/tsFreeList.h
Installing generic include file ../../../include/epicsSingleton.h
Installing generic include file ../../../include/epicsGuard.h
Installing generic include file ../../../include/epicsOnce.h
Installing generic include file ../../../include/dbmf.h
Installing generic include file ../../../include/ellLib.h
Installing generic include file ../../../include/envDefs.h
Installing generic include file ../../../include/epicsPrint.h
Installing generic include file ../../../include/errMdef.h
Installing generic include file ../../../include/errSymTbl.h
Installing generic include file ../../../include/errlog.h
Installing generic include file ../../../include/error.h
Installing generic include file ../../../include/fdManager.h
Installing generic include file ../../../include/fdmgr.h
Installing generic include file ../../../include/freeList.h
Installing generic include file ../../../include/gpHash.h
Installing generic include file ../../../include/iocLog.h
Installing generic include file ../../../include/logClient.h
Installing generic include file ../../../include/macLib.h
Installing generic include file ../../../include/adjustment.h
Installing generic include file ../../../include/cantProceed.h
Installing generic include file ../../../include/dbDefs.h
Installing generic include file ../../../include/epicsConvert.h
Installing generic include file ../../../include/epicsExit.h
Installing generic include file ../../../include/epicsStdlib.h
Installing generic include file ../../../include/epicsString.h
Installing generic include file ../../../include/epicsTypes.h
Installing generic include file ../../../include/shareLib.h
Installing generic include file ../../../include/epicsExport.h
Installing generic include file ../../../include/unixFileName.h
Installing generic include file ../../../include/locationException.h
Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h
Installing generic include file ../../../include/compilerDependencies.h
Installing generic include file ../../../include/epicsUnitTest.h
Installing generic include file ../../../include/testMain.h
Installing os dependent include file ../../../include/os/WIN32/osiFileName.h
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
Installing generic include file ../../../include/osiSock.h
Installing os dependent include file ../../../include/os/WIN32/osdSock.h
Installing generic include file ../../../include/epicsInterrupt.h
Installing os dependent include file ../../../include/os/WIN32/osdInterrupt.h
Installing generic include file ../../../include/epicsMutex.h
Installing os dependent include file ../../../include/os/WIN32/osdMutex.h
Installing generic include file ../../../include/epicsEvent.h
Installing os dependent include file ../../../include/os/WIN32/osdEvent.h
Installing os dependent include file ../../../include/os/WIN32/epicsMath.h
Installing os dependent include file ../../../include/os/WIN32/osdMessageQueue.h
Installing os dependent include file ../../../include/os/WIN32/osdStrtod.h
Installing generic include file ../../../include/epicsAssert.h
Installing generic include file ../../../include/epicsFindSymbol.h
Installing generic include file ../../../include/osiPoolStatus.h
Installing os dependent include file ../../../include/os/WIN32/osdPoolStatus.h
Installing os dependent include file ../../../include/os/WIN32/osdThread.h
Installing generic include file ../../../include/epicsThread.h
Installing generic include file ../../../include/epicsTime.h
Installing os dependent include file ../../../include/os/WIN32/osdTime.h
Installing generic include file ../../../include/epicsSignal.h
Installing generic include file ../../../include/osiProcess.h
Installing os dependent include file ../../../include/os/WIN32/osiUnistd.h
Installing generic include file ../../../include/osiWireFormat.h
Installing os dependent include file ../../../include/os/WIN32/osdWireFormat.h
Installing os dependent include file ../../../include/os/WIN32/epicsReadline.h
Installing generic include file ../../../include/epicsMessageQueue.h
Installing generic include file ../../../include/epicsStdio.h
Installing generic include file ../../../include/epicsStdioRedirect.h
Installing os dependent include file ../../../include/os/WIN32/epicsGetopt.h
Installing generic include file ../../../include/devLib.h
Installing os dependent include file ../../../include/os/WIN32/osdVME.h
Installing generic include file ../../../include/taskwd.h
Installing generic include file ../../../include/epicsTimer.h
Installing generic include file ../../../include/tsDefs.h
../../../src/libCom/bucketLib/bucketLib.c: In function 'ITEM** bucketStringCompa
re(ITEM**, const void*)':
../../../src/libCom/bucketLib/bucketLib.c:216:21: error: invalid conversion from
'const void*' to 'const char*'
../../../src/libCom/bucketLib/bucketLib.c: In function 'BUCKETID bucketUnsignedH
ash(BUCKET*, const void*)':
../../../src/libCom/bucketLib/bucketLib.c:238:25: error: invalid conversion from
'const void*' to 'const unsigned int*'
../../../src/libCom/bucketLib/bucketLib.c: In function 'BUCKETID bucketStringHas
../../../src/libCom/bucketLib/bucketLib.c:288:21: error: invalid conversion from
mingw32-make[3]: *** [bucketLib.o] Error 1
mingw'
mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
mingw32-make[2]: Leaving directory `c:/epics/base-3.14.9/src/libCom'
mingw32-make[1]: *** [libCom.install] Error 2
mingw32-make[1]: Leaving directory `c:/epics/base-3.14.9/src'
mingw32-make: *** [src.install] Error 2
Morgan Bradford, B.E., E.I.T.
Jr. Accelerator Physicist
Canadian Light Source Inc.
Phone: 306.657.3729
Email: [email protected]
Errors building EPICS with MinGW Morgan Bradford
Prev: Re: Creating a Simple EPICS Sequencer Program Bradley Pietrzak
Next: Re: EPICS Soft IOC hardware switch Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Errors building EPICS with MinGW Andrew Johnson
Next: Pcas is a Python binding to portable channel access server Wang Xiaoqiang
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
