Hi Dirk,
On 2011-07-07 Dirk Zimoch wrote:
> Can anyone tell me the differences between ppc603 and ppc604 from the
> software point of view? Are there instructions that one type supports
> and the other doesn't?
I think the main differences are some of the special-purpose registers (SPRs)
that are accessible at Supervisor level, used for obscure things like
performance monitoring and power or thermal management. The basic instruction
set is common to all 32-bit PowerPC CPUs, so it's only if you're doing BSP-
level things like turning Caches on/off or programming the MMU that the
differences really matter. The SPRs are accessed using the mtspr and mfspr
instructions. There are also a few optional and implementation-specific
instructions that the two Microprocessor Technical Summary documents I found
online mention briefly.
I added two new target architectures to Base 3.14.12.1, vxWorks-ppc32 and
vxWorks-ppc32sf (soft-float) so sites don't have to compile the code more than
is really necessary. Here at APS we're using them as part of our switch to
vxWorks 6.8, so our engineers can convert IOCs to 3.14.12.1 using the old
targets on vxWorks 5.5.2, but then switch to 6.8 using the same release of
Base with the new targets so we can separate out any issues due to the OS-
version.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Re: PPC603 / PPC604 differences? Till Straumann
- PPC603 / PPC604 differences? Dirk Zimoch
Re: EDM and record processing Ned Arnold
RE: EDM and record processing Szalata, Zenon M.
<2011>
<2011>
