Not to discourage reading the documentation thourougly but...
The biggest hold back to starting the make on epics base is defining
the environment EPICS_HOST_ARCH. For your system, this will either
be linux-x86 or linux-x86_64. If you are looking to just take a
test drive and run a softIOC on Linux then this is sufficient. If
not, you will need to configure your target environment, see the
second link from Marcio below for supported platforms &
compilers.
Once you have base built, Section 2 of the App Developer Guide will
get you through setting up an IOC. I would suggest getting the
example up and running as a start.
Once this is up and running you will probably need some tools to
"see" your IOC. For this, look at Michael's section on EDM or take
a look at CSS (http://sourceforge.net/apps/trac/cs-studio/wiki).
John
On 7/7/2011 9:19 AM, Márcio Paduan Donadio wrote:
On
07.07.2011 14:28, vivek chalotra wrote:
Hello all !
I am new to EPICS and i want to install it under
Scientific Linux CERN 5.5.
So please let me know the installation instructions.
Computer Engineer
SOL - Software de Operação das
Linhas de Luz (Beamline Software Operation)
Laboratório Nacional de Luz Síncrotron – CNPEM/ABTLuS
+ 55 (19) 3512-3520
[email protected]
www.lnls.br
John Hammonds
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]<mailto:[email protected]>
(630)252-5317
- Re: Installation of EPICS Márcio Paduan Donadio
RE: AreaDetector CBF file writing plugin emma.shepherd
Re: EDM and record processing Andrew Johnson
<2011>
Errors building EPICS with MinGW Morgan Bradford
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
