1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: fft
To: <[email protected]>, <[email protected]>
Date: Tue, 21 Jun 2011 12:31:21 -0600
Michael,
Some years back I implemented the spectrum record which employs a chirp Z
transform (two successive fft transforms provide the spectrum fo <= freq <=
f1).
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Michael Davidsaver
> Sent: Tuesday, June 21, 2011 11:43 AM
> To: [email protected]
> Subject: fft
> Has anyone done a routine for the aSub record (or similar) which does an
> fft?
> My input is complex data (two waveforms I and Q) as a function of time
> (512 samples).  Data updates come at ~5Hz.
> I was thinking of using
> http://www.fftw.org/fftw3_doc/Complex-DFTs.html#Complex-DFTs
> Suggestions?
fft Michael Davidsaver
Prev: Re: fft Andrew Johnson
Next: Re: fft Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
