1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: radiation damage to electronics inside accelerator tunnel?
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>, Josh Stein <[email protected]>, Richard Farnsworth <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Ringwall, Andrew D." <[email protected]>, "'[email protected]'" <[email protected]>, "Dao, Tom T." <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 20 Jun 2011 12:21:04 -0700
	Folks,
Let me add another data point to the vulnerability of SSI encoders inside the beam tunnel near beam height.  We've had *seven* unrecoverable TR Electronics LT Series failures as well as a few Hall effect limit switch failures at SPEAR.  Shielding with ~1 cm of Pb seems to have fixed (or slowed down?) the failure rate.
Potentiometers and LVDTs inside the tunnel make a great deal of sense.
                              --Harvey
Harvey Rarback                   phone: (650)926-3963
SLAC National Accelerator Lab    fax:   (650)926-4100
2575 Sand Hill Road              home phone: (650)560-9111
Menlo Park, CA 94025             [email protected]
                                 http://ssrl.slac.stanford.edu/~rarback
   "Always tell the truth, that way you don't have to keep track."
                            Pogo
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Hu, Yong
> Sent: Monday, June 20, 2011 9:24 AM
> To: [email protected]; Josh Stein; Richard Farnsworth;
> [email protected]; [email protected]
> Cc: [email protected]
> Thanks a lot for all of you sharing experiences and giving suggestions
> which are really helpful for me to convince our Diagnostics Group to
> re-design cabling and shielding.
> Regarding position measurement encoder, we're going to use Potentiometer
> and LVDT with stepper motor for beam diagnostics (slits, scrapers,
> etc.). We think these kinds of analog encoders might have better
> resistance to EMI and radiation.
> Yong
Re: radiation damage to electronics inside accelerator tunnel? Mohan Ramanathan
radiation damage to electronics inside accelerator tunnel? Hu, Yong
RE: radiation damage to electronics inside accelerator tunnel? austen.rose
RE: radiation damage to electronics inside accelerator tunnel? Hu, Yong
Prev: Re: EPICS_DEPRECATED and gcc-2.96 Andrew Johnson
Next: RE: asyn connection management with asynPortDriver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: radiation damage to electronics inside accelerator tunnel? Hu, Yong
Next: Re: radiation damage to electronics inside accelerator tunnel? Mohan Ramanathan
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
