1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: a puzzle about using stream device driver
To: <[email protected]>, "tech-talk" <[email protected]>
Date: Mon, 20 Jun 2011 09:55:31 -0500
I don't think you can use I/O Intr, because the device only provides a
new value of the optical scale value when you ask for it.  If it sent
unsolicited updates of this value then you could use I/O Intr, but that
is not how most devices work.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Silver
Sent: Monday, June 20, 2011 9:42 AM
To: tech-talk
Subject: a puzzle about using stream device driver
hi,
I am using stream device driver to communicate a galil motion control
which model is dmc21x3. To  get the value of optical scale, I use a ai
record like this:
record(ai,"$(PREFIX):opticalscale")
        field (DESC, "opticalscale position")
        field (DTYP, "stream")
        field (INP, "@dmc2143.proto ai_opticalscale motor")
        field (SCAN, ".5 second")
In that, I use the period scan. It works fine.
But in most of time, the value doesn't change. That means the IOC has to
communicate with device periodly. As the value only changes during the
motor moving,  may I use I/O Intr mode?
I checked the online document of stream device, seems the I/O Intr mode
is not suitable for this case. Is there any good ways to avoid checking
the devcie periodly?
Thanks a lot for your help.
Best regards
Geyang  2011-06-20
a puzzle about using stream device driver Silver
Prev: RE: a puzzle about using stream device driver matthew.pearson
Next: RE: radiation damage to electronics inside accelerator tunnel? austen.rose
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: a puzzle about using stream device driver Davidsaver, Michael
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
