hi,
I am using stream device driver to communicate a galil motion control which model is dmc21x3. To get the value of optical scale, I use a ai record like this:
record(ai,"$(PREFIX):opticalscale")
field (DESC, "opticalscale position")
field (DTYP, "stream")
field (INP, "@dmc2143.proto ai_opticalscale motor")
field (SCAN, ".5 second")
In that, I use the period scan. It works fine.
But in most of time, the value doesn't change. That means the IOC has to communicate with device periodly. As the value only changes during the motor moving, may I use I/O Intr mode?
I checked the online document of stream device, seems the I/O Intr mode is not suitable for this case. Is there any good ways to avoid checking the devcie periodly?
Thanks a lot for your help.
Best regards
Geyang 2011-06-20
- RE: a puzzle about using stream device driver matthew.pearson
- RE: a puzzle about using stream device driver Mark Rivers
- RE: a puzzle about using stream device driver Davidsaver, Michael
Bronkhorst E-7000 series -stream device support? Burkhard Kolb
<2011>
<2011>
