1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SOAP device communication.
To: Scott Baily <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 17 Jun 2011 16:12:04 -0500
On 6/17/11 3:44 PM, Scott Baily wrote:
> I would like to have an IOC talk to hardware that communicates
> using SOAP.  In theory, I could setup an appropriate protocol
> file for Streamdevice and use a raw TCP connection to port 80.
> Has anyone done this?  Is there a better method?
Hi, Scott.
If you can get that to work with your particular device, that
may be the easiest solution.  I've done something similar just
using asyn records to query readings from a temperature and
humidity sensor via HTTP.
A better method, but more work, would be to actually use a SOAP
library on the IOC to communicate with the device.  Since SOAP
uses XML, you would need an XML parser which would typically be
included with or used by your SOAP library.  With your
StreamDevice approach, you are really just doing pattern
matching which is likely to work with your particular device,
but could fail given a different device implementing the same
API (e.g. XML allows whitespace characters in lots of places and
one device could place them differently than another).
While not perfect, in most situations I'd probably do something
like what you are thinking with StreamDevice (or asyn records).
Lewis
Re: SOAP device communication. Peter Milne
SOAP device communication. Scott Baily
Prev: SOAP device communication. Scott Baily
Next: Re: SOAP device communication. Peter Milne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
