1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Hardware needed to setup an IOC
To: <[email protected]>, <[email protected]>
Date: Thu, 16 Jun 2011 15:50:19 +0000
Hi Andrew,
It depends how much data you are transferring/handling of course. But I would expect any modern PC will do the job.
For example, on our beamlines here we use one Dell R200 server to talk to >10 ethernet based motor controllers, with minimal impact on CPU and memory.
I did a test a few years ago with a 2GHz Pentium 4 desktop. I connected up 12 ethernet motor controllers. Polling two of them at 20Hz (each poll reading all 8 axes), and polling the rest at 2Hz. I was seeing about  4% CPU use.
Also, Epics is designed to have small memory footprint as it runs on all sorts of embedded devices.
Cheers,
Matthew
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Cox
Sent: 14 June 2011 22:28
To: [email protected]
Subject: Hardware needed to setup an IOC
Hi All,
I am a newbie to EPICS and I wanted to see what kind of hardware is needed to install a soft IOC. I wanted to control upto 25 LAN/ GPIB/ USB devices with more in the future.
The devices include Power supplies, oscilloscopes, Signal generators, EPICS supported other test equipment.
Will a dell computer with Red hat lInux and a few cisco network switches work for so many devices or do I need a server class computer ?
I am fairly new to EPICS and I do not know the requirements.
I will appreciate if you guys can lead me in the right direction.
Andrew
Hardware needed to setup an IOC Andrew Cox
Prev: Re: Hardware needed to setup an IOC Andrew Johnson
Next: Re: Sequencer Preprocessor Build Rules Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: AreaDetector: Prosilica camera on different subnet? Bob Gunion
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
