Kay, et. al.,
I grabbed the latest snap-shot of SNS CSS source (3.0.0) from
http://ics-web.sns.ornl.gov/css/products.html
and my problems with Probe and OPI features are solved.
Note that in this version I do see errors related to adl2boy. I have
attached the associated @dot.log file.
Thanks
On 6/10/2011 4:40 PM, Kasemir, Kay wrote:
Dear tech-talkers:
An update after some internal emails
On 6/10/11 12:48 , "John Dobbins"<[email protected]> wrote:
Linux ... live PVs don't connect
Turned out to be caused by multiple network interfaces
on that Linux computer, requiring adjustments
to the EPICS addr list.
1) if I choose menu item CSS -> Dignostic Tools -> Probe
nothing appears to happen
We found the symptom in the log file (<workspace>/.metadata/.log)
java.lang.Error: Unresolved compilation problems:
at org.csstudio.diag.probe.Probe.<init>(Probe.java:147)
We have not, yet, been able to determine why that is happening.
-Kay
# 6/13/11 9:42:23 AM EDT
# Eclipse Compiler for Java(TM) 0.A76_R36x, 3.6.2, Copyright IBM Corp 2000, 2010. All rights reserved.
1. WARNING in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\EditADLHandler.java (at line 54)
for (Iterator<Object> iterator = strucSelection.iterator(); iterator.hasNext(); ){
Type safety: The expression of type Iterator needs unchecked conversion to conform to Iterator<Object>
2. WARNING in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\EditADLHandler.java (at line 112)
private void printNotHandledMessage(String type) {
The method printNotHandledMessage(String) from the type EditADLHandler is never used locally
3. WARNING in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\EditADLHandler.java (at line 115)
private void printNotCompletelyHandledMessage(String type) {
The method printNotCompletelyHandledMessage(String) from the type EditADLHandler is never used locally
4. WARNING in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\Perspective.java (at line 11)
private static final String ID_TOP = "topFolder";
The field Perspective.ID_TOP is never read locally
5. ERROR in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\WriteADLColorMapHandler.java (at line 27)
public void addHandlerListener(IHandlerListener handlerListener) {
The method addHandlerListener(IHandlerListener) of type WriteADLColorMapHandler must override a superclass method
6. ERROR in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\WriteADLColorMapHandler.java (at line 36)
public void dispose() {
The method dispose() of type WriteADLColorMapHandler must override a superclass method
7. ERROR in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\WriteADLColorMapHandler.java (at line 45)
public Object execute(ExecutionEvent event) throws ExecutionException {
The method execute(ExecutionEvent) of type WriteADLColorMapHandler must override a superclass method
8. ERROR in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\WriteADLColorMapHandler.java (at line 62)
public boolean isEnabled() {
The method isEnabled() of type WriteADLColorMapHandler must override a superclass method
9. ERROR in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\WriteADLColorMapHandler.java (at line 71)
public boolean isHandled() {
The method isHandled() of type WriteADLColorMapHandler must override a superclass method
10. ERROR in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\WriteADLColorMapHandler.java (at line 80)
public void removeHandlerListener(IHandlerListener handlerListener) {
The method removeHandlerListener(IHandlerListener) of type WriteADLColorMapHandler must override a superclass method
11. WARNING in C:\USER_LOCAL\jad\sns_css_3.0.0\org.csstudio.opibuilder.adl2boy\src\org\csstudio\opibuilder\adl2boy\translator\TranslatorUtils.java (at line 150)
Class classToMove) {
Class is a raw type. References to generic type Class<T> should be parameterized
11 problems (6 errors, 5 warnings)
- Re: SNS CSS org.csstudio.basic.epics.product Kasemir, Kay
patch for MCA Against Matlab 2011a Shen, Guobao
<2011>
<2011>
