Hi Mark,
A bit more information about why I am confused. If the asynPortDriver class is instantiated with autoConnect disabled then the PCNCT field
of the asynRecord shows 'Connect' which I think means the port is connected. However asynReport in the IOC says the port isn't connected.
There doesn't seem to be a mechanism for connecting the port itself except via autoConnect, although I think that the ::connect method called with addr=-1 is what the documentation implies.
e.g.
epics> asynReport 4
drx1 multiDevice:Yes canBlock:Yes autoConnect:No
enabled:Yes connected:No numberConnects 0
epics> dbpr as:t:as01:drx:s1:asynRecord 4
ACKS: NO_ALARM ACKT: YES ACMD: None ADDR: 0
AINP: AOUT: AQR: 0 ASG:
ASP: (nil) AUCT: noAutoConnect BAUD: Unknown BINP: 0
BKPT: 00 BOUT: 0 CNCT: Disconnect DBIT: Unknown
DESC: DISA: 0 DISP: 0 DISS: NO_ALARM
DISV: 1 DPVT: 0xaa61c40 DRVINFO: DSET: 0xb7740988
DTYP: asynRecordDevice ENBL: Enable EOMR: None
ERRS: 0xaa61f20 EVNT: 0 F64INP: 0 F64IV: 1
F64OUT: 0 FCTL: Unknown FLNK:CONSTANT 0 GPIBIV: 0
I32INP: 0 I32IV: 1 I32OUT: 0 IEOS:
IFACE: asynOctet IFMT: ASCII IMAX: 80 IPTR: 0xaa61e70
LCNT: 0 LSET: 0xb6c75078 MCTL: Unknown
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 MLOK: 28 1c a6 0a
NAME: as:t:as01:drx:s1:asynRecord NAWT: 0 NORD: 0
NOWT: 80 NRRD: 0 NSEV: NO_ALARM NSTA: NO_ALARM
OCTETIV: 1 OEOS: OFMT: ASCII OMAX: 80
OPTIONIV: 0 OPTR: 0xaa61e18 PACT: 0 PCNCT: Connect
PHAS: 0 PINI: NO PORT: drx1 PPN: (nil)
PPNR: (nil) PRIO: LOW PROC: 0 PRTY: Unknown
PUTF: 0 RDES: 0x9dc5570 REASON: 0 RPRO: 0
RSET: 0xb7740940 SBIT: Unknown SCAN: Passive SDIS:CONSTANT
SEVR: NO_ALARM SOCK: SPR: 0 SPVT: (nil)
STAT: NO_ALARM TB0: On TB1: Off TB2: Off
TB3: Off TB4: Off TFIL: Unknown TIB0: Off
TIB1: Off TIB2: Off TIME: <undefined> TINP:
TIOM: 0 TMOD: Write/Read TMOT: 1 TMSK: 1
TPRO: 0 TSE: 0 TSEL:CONSTANT TSIZ: 80
UCMD: None UDF: 0 UI32INP: 0 UI32IV: 1
UI32MASK: 4294967295 UI32OUT: 0 VAL:
cheers,
Euan.
On 10/06/2011, at 2:16 AM, Mark Rivers wrote:
> Hi Euan,
> I am away from the lab, but I will look into this and get you an answer when I return on June 20. It seems like the asyn record should do what you want, but maybe something is wrong.
> Meanwhile perhaps Eric Norum can help :-)
> Mark
> ________________________________
> From: [email protected] on behalf of [email protected]
> Sent: Wed 6/8/2011 8:25 PM
> To: [email protected]
> Subject: asyn connection management with asynPortDriver
> Hi,
> I would like to use the connection management features of asyn with a driver based on the asynPortDriver class. If I create the port driver class with the autoconnect flag set to true I can use the asynRecord CNCT field to connect or disconnect a device from the port. If autoconnect is set to false, then when the IOC starts up, the following messages appear:
> iocRun: All initialization complete
> epics> 2011/06/09 10:51:51.625 as:t:as01:drx:s1:asynRecord: queueRequest failed for special.
> 2011/06/09 10:51:51.625 as:t:as01:drx:s1:asynRecord: port drx1 not connected
> If I try and use the CNCT field if the asyn record to connect a device then a similar message is produced:
> epics> 2011/06/09 11:00:29.564 as:t:as01:drx:s1:asynRecord: exception 2
> 2011/06/09 11:00:39.172 as:t:as01:drx:s1:asynRecord: queueRequest failed for special.
> 2011/06/09 11:00:39.172 as:t:as01:drx:s1:asynRecord: port drx1 not connected
> As I understand the setup, the asynPortDriver constructor will connect the port and the class methods connect() and disconnect() will connect devices to the port. I have derived these methods in my class so that I can manage connections but without autoconnect to make the first connection these methods are not called. So even though the port is connected, without autoconnect I can't connect any devices to the port. I guess there is some setup I haven't performed. I would like advice as to how to manage the connections. I am using asyn 4.16 with EPICS 3.14.12.
> cheers,
> Euan.
- RE: asyn connection management with asynPortDriver Mark Rivers
- asyn connection management with asynPortDriver Euan.Troup
Re: Sequencer Preprocessor Build Rules J. Lewis Muir
driver support for SIS3302 and SIS3305 Hu, Yong
<2011>
<2011>
