I would like to use the connection management features of asyn with a driver based on the asynPortDriver class. If I create the port driver class with the autoconnect flag set to true I can use the asynRecord CNCT field to connect or disconnect a device from the port. If autoconnect is set to false, then when the IOC starts up, the following messages appear:
epics> 2011/06/09 10:51:51.625 as:t:as01:drx:s1:asynRecord: queueRequest failed for special.
2011/06/09 10:51:51.625 as:t:as01:drx:s1:asynRecord: port drx1 not connected
If I try and use the CNCT field if the asyn record to connect a device then a similar message is produced:
epics> 2011/06/09 11:00:29.564 as:t:as01:drx:s1:asynRecord: exception 2
2011/06/09 11:00:39.172 as:t:as01:drx:s1:asynRecord: queueRequest failed for special.
2011/06/09 11:00:39.172 as:t:as01:drx:s1:asynRecord: port drx1 not connected
As I understand the setup, the asynPortDriver constructor will connect the port and the class methods connect() and disconnect() will connect devices to the port. I have derived these methods in my class so that I can manage connections but without autoconnect to make the first connection these methods are not called. So even though the port is connected, without autoconnect I can't connect any devices to the port. I guess there is some setup I haven't performed. I would like advice as to how to manage the connections. I am using asyn 4.16 with EPICS 3.14.12.
cheers,
Euan.
- RE: asyn connection management with asynPortDriver Mark Rivers
RE: Problem with caget on 3.14.12.1? Jeff Hill
APS Website issues Andrew Johnson
<2011>
RE: Request for opinions about device driver/support Hu, Yong
<2011>
