Hi -
You should probably look at Mark Rivers' areaDetector ... he has solved most of the problems with image type data in a very modular fashion. If your needs are somewhat different just add a plug-able module.
http://cars9.uchicago.edu/software/epics/
Ned
On Jun 6, 2011, at 9:28 AM, Paweł Prędki wrote:
> W dniu 2011-06-06 15:33, Kasemir, Kay pisze:
>> On 6/6/11 08:59 , "Paweł Prędki"<[email protected]> wrote:
>>> Is it possible to do such a thing in BOY? There is an Image widget but I
>>> believe it's for static images only.
>> The "Intensity Graph" widget displays waveforms that are really grayscale
>> images.
>> For example:
>> waveform with 10000 elements, "width" 100 means:
>> Elements 0...99 are the first row of the image,
>> elements 100..199 are the second row of the image and so on.
>> You need to specify the minimum and maximum element value,
>> like 0 and 255, which will then be mapped to black...white
>> or some other color map of your choosing.
>> -Kay
> Hello Kay,
> Thanks for your reply. That would be a good way to do it for one-channel (grayscale) images. I believe the cameras we will be dealing with will provide RGB (color) images.
> I understand there is no straightforward way to do it. There is no image record type in EPICS that clients could understand. Do you think there is a need for such a thing? Like you said, a simple waveform could store such raw image data in a BMP format without a header and the clients would then be able to draw it.
> Regards,
> Paweł Prędki
> Technical University of Lodz
> Department of Microelectronics and Computer Science
> ul. Wolczanska 221/223, 90-924 Lodz, Poland
> tel. +4842 6312720
- Re: Dynamic images in BOY Kasemir, Kay
- Re: Dynamic images in BOY Paweł Prędki
Re: Compiling Problem windows J. Lewis Muir
<2011>
<2011>
