Hi, there,
After I installed bison and flex, it worked. Now I run "./mkCrossGCC
CPU=<cpu> build", it has an error message as below. Could you
tell me how I could fix it?
Thank you.
Chen
make[3]: *** No rule to make target `../intl/libintl.a', needed by
`ld-new'. Stop.
make[3]: Leaving directory
`/root/cross-compiler-build-dir/obj-ppc/ld'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
make[1]: *** [all-recursive-am] Error 2
make[1]: Leaving directory
make[1]: Entering directory
Making install in po
make[2]: Entering directory
`/root/cross-compiler-build-dir/obj-ppc/ld/po'
if test -r /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/po/../../mkinstalldirs; then \
/home/chen/Cross-Compiler/host/x86-linux/share; \
else \
/home/chen/Cross-Compiler/host/src/gnu.ppc/ld/mkinstalldirs
fi
if test "ld" = "gettext"; then \
/home/chen/Cross-Compiler/host/x86-linux/share/gettext/po; \
else \
fi; \
/usr/bin/install -c -m 644
/home/chen/Cross-Compiler/host/src/gnu.ppc/ld/po/Makefile.in.in \
/home/chen/Cross-Compiler/host/x86-linux/share/gettext/po/Makefile.in.in;
else \
fi
make[2]: *** No rule to make target `../intl/libintl.a', needed by
`ld-new'. Stop.
make[1]: *** [install-recursive] Error 1
make: *** [ld.build] Error 2
On 6/3/2011 10:24 AM, Jeff Hill wrote:
you may need to install flex and bison
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
-----Original Message-----
On Behalf Of Chen Xue
Sent: Friday, June 03, 2011 9:06 AM
To: [email protected]
Subject: cross compiler error
Hi, there,
I will install the EPICS Server under vxWorks version 5.4.2 (for
Motorola MVME 5100). I downloaded the cross-compiler file,
cross-gcc-2.9.6.tar.gz, for linux from http://ics-web.sns.ornl.gov/dht/.
Untar it and configured WIND_BASE in mkCrossGCC file. When I run
./mkCrossGCC CPU=ppc, I got the following error message. Could someone
help me?
Fixing /root/cross-compiler-build-dir/obj-ppc/cpp/gcc/Makefile to add CPU
cd /root/cross-compiler-build-dir/obj-ppc/cpp/gcc ; mv Makefile
Makefile.orig ;\
sed 's/^CROSS=/CROSS=-DCPU=PPC603 /' <Makefile.orig >Makefile
========= Building gas.config
mkdir -p /root/cross-compiler-build-dir/obj-ppc/gas
cd /root/cross-compiler-build-dir/obj-ppc/gas ;\
/home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure
--with-cpu=603 --prefix=/home/chen/Cross-Compiler/host/x86-linux
--target=powerpc-wrs-vxworks --host=i386-redhat-linux
--with-headers=/home/chen/Cross-Compiler/target/h -enable-bfd-assembler
loading cache ./config.cache
checking for Cygwin environment... (cached) no
checking for mingw32 environment... (cached) no
checking host system type... i386-redhat-linux-gnu
checking target system type... powerpc-wrs-vxworks
checking build system type... i386-redhat-linux-gnu
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for POSIXized ISC... no
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... missing
checking for working autoconf... missing
checking for working automake... missing
checking for working autoheader... missing
checking for working makeinfo... found
checking for ld used by GCC... (cached) /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... (cached) yes
checking for /usr/bin/ld option to reload object files... (cached) -r
checking for BSD-compatible nm... (cached) /usr/bin/nm -B
checking whether ln -s works... (cached) yes
checking how to recognise dependant libraries... (cached) pass_all
checking for object suffix... (cached) o
checking for executable suffix... (cached) no
checking for ranlib... (cached) ranlib
checking for strip... (cached) strip
loading cache ./config.cache within ltconfig
checking whether -lc should be explicitly linked in... (cached) no
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... (cached) yes
checking if gcc static flag -static works... (cached) yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -fno-rtti -fno-exceptions ... no
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking command to parse /usr/bin/nm -B output... ok
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
creating libtool
checking whether the C compiler (gcc -g -O2 ) works... yes
checking whether the C compiler (gcc -g -O2 ) is a cross-compiler... no
checking for bison... no
checking for byacc... no
checking how to run the C preprocessor... gcc -E
checking for flex... no
checking for lex... no
/home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 3437: flex:
not found
checking for flex... lex
checking for yywrap in -ll... no
checking lex output file root...
/home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 1: lex: not
found
configure: error: cannot find output from lex; giving up
make: *** [gas.config] Error 1
Thank you!
Chen
- RE: cross compiler error Jeff Hill
- cross compiler error Chen Xue
Re: cross compiler error J. Lewis Muir
Mutex at the record level? Steiner, Mathias
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
