Fixing example.. still same result:
import epics
import time
import sys
def onConnectionChange(pvname=None, conn=None, chid=None):
print 'ca connection status changed: ', time.time(), pvname,
conn, chid
sys.stdout.flush()
# create channel, provide connection callback
pv1 = 'HINKS:ENV:ENV_VOLTAGE1_MONITOR'
chid1 = epics.ca.create_channel(pv1, connect=False,
callback=onConnectionChange)
pv2 = 'HINKS:ENV:ENV_VOLTAGE2_MONITOR'
chid2 = epics.ca.create_channel(pv2, connect=True,
time.sleep(1)
print "ca._cache:", epics.ca._cache
print 'Now waiting, watching values and connection changes:'
t0 = time.time()
while time.time()-t0 < 30:
time.sleep(0.001)
print "Exiting .."
Output:
$ python caconnect.py
ca connection status changed: 1307004453.64
HINKS:ENV:ENV_VOLTAGE1_MONITOR True 157644296
HINKS:ENV:ENV_VOLTAGE2_MONITOR True 157644328
ca._cache: {155204176: {'HINKS:ENV:ENV_VOLTAGE2_MONITOR': {'callbacks':
[<function onConnectionChange at 0x9591cdc>], 'failures': 0, 'chid':
157644328, 'conn': True, 'ts': 1307004453.635572},
'HINKS:ENV:ENV_VOLTAGE1_MONITOR': {'callbacks': [<function
onConnectionChange at 0x9591cdc>], 'failures': 0, 'chid': 157644296,
'conn': True, 'ts': 1307004453.635221}}}
Exiting ..
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
- pyEpics want postponed connecting Hinko Kocevar
Re: caget command holds for more than 10 seconds Hinko Kocevar
<2011>
Re: pyEpics want postponed connecting Matt Newville
<2011>
